391 Door Trim Replacement
The black, shiny, plastic door trim has broken on my unit. This is a U-shaped strip that runs in a channel mounted on the outside just under the door. The trim is there to cover screws that secure the outer body over the door frame. Shoes tend to toe into this piece going up the entry steps so it cracked. Any ideas where I can get replacements. Most of the trim searches I've done get me to flat stuff not the U-shaped I need.
George
2007 391TS UFO Chassis
