Old 05-02-2015, 05:55 PM   #31
Is it not true that the neutral and ground are tied to the same terminal back at the main breaker box?
Old 05-02-2015, 06:15 PM   #32
Witch Doctor's Avatar
You are kinda right they are both tied to the box, and you could use a ground for a neutral from a 50 amp breaker and get 110v I wouldn't recommend it. When I did A/C repair and needed 110 V . I had a 110v receptacle with 2 wires and alligator clamps on them I would hook 1 clamp to 1 lug in the disconnect and the other alligator to the box itself that gave me 110 V to use on roof tops for my equipment that I needed that was 110v. Now a day's the code requires a 110 box at the unit also. But yes it would give you 110v. 1 hot leg and a ground. But as the article says the car plug is most likely a welders config. 3 prong and not a 4 prong RV plug. So really I do not know what he's trying to do?
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 05-03-2015, 08:04 PM   #33
chrisbailey13's Avatar
My RV breaker looks similar to the one the OP posted in #6, one thing that is missing from his picture is if there is a Neutral Bar in the breaker box that may not be shown in the picture.
if there is it would alleviate a lot of the speculation that the electrician wired the outlet wrong.
2014 Georgetown XL 352QS
2013-2017 Days Camped-215
chrisbailey13 is offline   Reply With Quote
Old 05-03-2015, 08:19 PM   #34
I've always had welder's and they have all been wired with 2 hot, a neutral and a ground wire on the receptacle itself even tho the plugs only have 3 lugs. Have always used 8-3 with ground.
Old 05-03-2015, 08:49 PM   #35
Have seen a lot of home 100A & 200A boxes where certified electricians have connected the neutral and ground to the same lug/terminal in the main box. The electrician could have if there were a ground wire, done the same in this incident, but evidently did not run a ground wire.
Old 05-03-2015, 09:04 PM   #36
fast murray's Avatar
What size is the wire going to that 50 amp breaker. It should be #8 but its tough to tell in the picture.
2004 Wildcat 28BH
2012 Ram 2500 CCSB 6.7CTD
fast murray is offline   Reply With Quote
Old 05-03-2015, 09:09 PM   #37
Originally Posted by johntaylor View Post
The power delivered to your house is 220V 2-phase
Just for fun, residential power is typically 240 volt 1 phase. There is no 2 phase power, only single phase and three phase.
2004 Wildcat 28BH
Old 05-03-2015, 09:37 PM   #38
Not so. The voltages in the 2 hot wires are 180 degrees out of phase. That makes it a 2-phase supply, and that's how you get 240V between the 2 hot wires. If the 2 hot wires were in phase, making it a 1-phase supply, you would have 0V between the hot wires. As you say, there is also 3-phase power; the 3 hot wires there are 120 degrees out of phase.
johntaylor is offline   Reply With Quote
Old 05-03-2015, 09:44 PM   #39
B and B's Avatar
Two Phase power does not exist. Either single phase like most homes or a 50 amp RV or 3 phase not found in RV
From Wilipedia..
Two-phase electrical power was an early 20th-century polyphase alternating current electric power distribution system. Two circuits were used, with voltage phases differing by one-quarter of a cycle, 90. Usually circuits used four wires, two for each phase. Less frequently, three wires were used, with a common wire with a larger-diameter conductor. Some early two-phase generators had two complete rotor and field assemblies, with windings physically offset to provide two-phase power. The generators at Niagara Falls installed in 1895 were the largest generators in the world at that time and were two-phase electric machines. As of 21st century, two-phase power was superseded with three phases and is not used in the industry. There remains, however, a two-phase commercial distribution system in Philadelphia, Pennsylvania; many buildings in city center are permanently wired for two-phase[citation needed] and PECO (the local electric utility company) has continued the service.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
B and B is online now   Reply With Quote
Old 05-03-2015, 09:55 PM   #40
TGR
TGR's Avatar
It looks like the view of the neutral/ground busbar in post #6 is partially obscured by the circuit breakers. However the busbar is visible in the slots without circuit breakers. The two white neutral wires are wired to the neutral/ground busbar and so are the two green wires.
Fast murrray is correct, residential homes are supplied by split-phase power, not 2-phase power.
2015 Wildcat 282 RKX
2011 F350 Lariat, 6.7 L. Diesel, 8 ft., SRW, Reese R20
TGR is offline   Reply With Quote
50 amp, electrical
