Old 04-29-2015, 09:41 PM   #1
50 amp outlet for RV's
Hey again,
I just had a 50 amp outlet installed and it works in our electric car. But when I plug the RV into it, it does not work.
This is related to my other topic of shoreline not working and after doing some digging I found out that my 110 cord works but not my 50 amp.
Is there a special wiring that is needed for RV's?
2008 Georgetown 370ts XL
E-man is offline   Reply With Quote
Old 04-29-2015, 09:54 PM   #2
B and B's Avatar
Hello, what kind of plug of the electric car use? You need a neutral for the RV to work.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
B and B is online now   Reply With Quote
Old 04-29-2015, 10:10 PM   #3
Sorry but could you clarify the question I just found out it should be two 120 hot legs and not 240 direct.
Is that what you mean?
Old 04-29-2015, 10:11 PM   #4
The electric car uses a 50 amp.
Old 04-29-2015, 10:14 PM   #5
Iggy's Avatar
Is it a 3 wire plug or 4 wire plug?
Is the breaker in the house one breaker or two hooked together(double size)?
Pictures would be good of your car plug as well as the one you installed in the house.
Is the cars 50 amp single phase meaning 1 hot (120volt) wire at 50 amps for the car?
TV 50 amp is two hot wires, 1 neutral and 1 ground wire. (4 prong)
Old 04-29-2015, 10:47 PM   #6
Name:	ImageUploadedByForest River Forums1430365606.482514.jpg
Here they are it appears they just have 3 wires.
Name:	ImageUploadedByForest River Forums1430365662.819856.jpg
Old 04-29-2015, 11:12 PM   #7
Iggy's Avatar
What I see is 2 hot wires and a green ground wire and no neutral(white wire) going out of the panel. You need to add a neutral (white) wire to the outlet.
Now the question is with a neutral wire hooked up to the plug have any effect on your car plug.
Who installed this plug? If it was a licensed electrician you need to ask him why he didn't install a neutral wire. May be the car didn't need it.
You need to find out more what the car needs.
Now if you find out that the car will not have any negative effects you can install a white wire from the neutral bus of the panel to the neutral on the receptacle and that should make the RV run fine. The RV needs this for everything to work.
Look at my picture again.
Hope this helps you understand.
Old 04-30-2015, 12:05 AM   #8
Batts-toy's Avatar
I also have a plug in car, be very careful the plug for the car charging is probably 220 volts on 50 amp breakers. if you plug your RV into a 220 volt house plug you will smoke a bunch of circuits in your RV. The 50 amp service for RV's is 2 separate 110 volt circuits (it is possible to feed a 220 volt appliance in an RV but the breaker in the RV intended for the 220 Volt appliance would then have to be wired for that purpose).
Looking at your pictures I would say Iggy is correct that the plug is missing the neutral wire for use with an RV, but it is also possible the plug is wired at 220 volts just saying you better be sure what you are dealing with or it could get very expensive very fast.
Dale & Terri, Lulu & Tiki (our Chihuahua's), New rescue puppy Prince - Pom/Pug mix.
2013 Tundra, Double Cab, 5.7, TRD Off-Road, 4X4, Full Tow Package
2013 Wildwood T26TBSS - Sold
2000 Gulf Stream Sun Voyager M-8357 MH, Ford Trident V10 Gasser, 35 foot.
Batts-toy is offline   Reply With Quote
Old 04-30-2015, 09:18 AM   #9
Thank you all for all the great feedback.
So I need to insure that the electrician installs the plug to meet the following criteria:
- The RV 50 amp needs to be two hot wires, 1 neutral and 1 ground wire. (4 prong)
- The 50 amp service for RV's is 2 separate 110 volt circuits.
So a question is from my picture above does it look like they installed 2 110 volt circuits or did they install a 1 220 circuit or is it clear from the picture?
Old 04-30-2015, 09:23 AM   #10
B and B's Avatar
From the picture they installed a 220 V service with no neutral. All you require is the White Wire or Neutral installed as per previous posters. This should not effect your car charger either.
The receptacle is upside down for a RV plug as well
50 amp, electrical
