Old 06-28-2016, 04:32 PM   #11
wmtire's Avatar
Originally Posted by uhduh camping View Post
Just to confuse you more, you will have 70 Amps less.
Correct, as stated a 50 amp 120/240 volt split phase service consists of two poles/legs, each at 50 amps or 100 amps (12000 watts) total.
A 30 amp 120 volt single phase service consists of one pole/leg, at 30 amps (3600 watts) total.
This link may help explain it better, and also the use of the adapter you have that will share the 30 amps across both legs to your RV
Electrical Tutorial - Chapter 3 - 30 Amp versus 50 Amp
2011 Flagstaff 831 RLBSS
Ive lost my scapegoat.
Old 06-28-2016, 04:56 PM   #12
TURBS's Avatar
Originally Posted by Mountndream View Post
please no pics of your legs.... or any other body parts...
Chicken
Sent from my SCH-R530U using Tapatalk
Old 06-28-2016, 04:58 PM   #13
Originally Posted by TURBS View Post
Chicken
me or your legs?
2015 Ram 2500 4x4 6.4l with 2015 Sandpiper 25RLS
Wife, myself and 2 furry kids
Mountndream is online now   Reply With Quote
Old 06-28-2016, 04:58 PM   #14
You can run everything, just not at the same time.
Steve29rlx is offline   Reply With Quote
Old 06-28-2016, 05:03 PM   #15
TURBS's Avatar
Old 06-28-2016, 05:20 PM   #16
Ned
Thanks everyone! Have a lot better idea of what's possible now.
Ned is offline   Reply With Quote
Old 06-28-2016, 06:20 PM   #17
TURBS's Avatar
Yeah running two a/c units on a 30 amp circuit isn't real wise and its obvious.
Old 06-28-2016, 06:44 PM   #18
HONDAMAN174's Avatar
Or...
Camco 55025 PowerGrip Maximizer 45 AMP Adapter https://www.amazon.com/dp/B0024E70L2..._FVWCxbBRTXN6K
2014 Evo 2850 "Woodstock"
2011 Toyota Tundra "Clifford"
Just glad to get away
Old 06-28-2016, 09:14 PM   #19
[QUOTE=HONDAMAN174;1242705]Or...
I believe that adapter only works if the 15amp outlets are on a different circuit than the 30amp. My understanding is most camp sites will trip once that adapter is attached.....(I am not an electrician or an expert)...
Melvinson404 is offline   Reply With Quote
Old 06-28-2016, 09:47 PM   #20
TURBS's Avatar
Id bet the 20 amp is tied to the 30 in some cases, which renders that adapter useless.
50 amp
