Old 06-28-2016, 03:54 PM   #1
Ned
50 amp vs 30 amp question
Just got a ' 14 351. It has 50amp service but not all campgrounds have 50 amp service. I know I can get a 30 amp adapter but what won't I be able to run 'cause of the 20 amp less load capacity? Thanks
Ned is offline   Reply With Quote
Old 06-28-2016, 03:58 PM   #2
I can run 2 AC's, however if I use the microwave it will kick, or possibly hair dryer or coffee maker. Probably do 1 AC and those items, you won't burn anything up you will just trip the breaker at the camp site.
I wish these units had a meter inside, my 05 Fleetwood did, it would also shed power if there wasn't enough juice.
2016 364TS
Kevin M. is offline   Reply With Quote
Old 06-28-2016, 04:04 PM   #3
hi Ned -
Welcome to the forums - typically you'll only be able to run one AC at a time, and be careful on the high-amp appliances (typically the microwave, hairdryer and the water heater if on electric) along with the 1 AC -
With that said, we've had our 351 for 2 years, camped multiple times with only 30 amp and have never blown anything. We keep the water heater on gas only, run 1 AC at a time and have never had an issue. We have a tower fan I set right next to the bunks by the fridge and it helps move air from the front to the back, or vice versa depending on where I'm running the AC (typically I'll cool the back, then switch to the front with the tower fan on) We also may cover the windows in the back if it's really sunny to help reflect the heat out and keep the back cool.
If you search, I've seen a list of the amps used by typical appliances, trick is to stay under 30. If I com across it again, I'll post a link (or maybe someone else will)
Lots of good information here about the GT - feel free to ask (or search!)
Garren
2015 Georgetown 351DS
2016 Jeep Wrangler Unlimited Sahara
Chris, Garren (humans)
Edgar & Carlos (felines)
RIP Sophie, the sweetest cat ever.
ChrisAndGarren is offline   Reply With Quote
Old 06-28-2016, 04:05 PM   #4
BandJCarm's Avatar
I have a 30 amp plug on side of garage at home, from last trailer. Got home in new 5'er yesterday and promptly plugged up the 50 amp power cord to the 30 amp plug, via a dogbone. BAM! Circuit breaker to whole garage tripped. I had left 'on' the power to Zone 1 and Zone 2 a/c and they came on automatically........bam. No way 30 amps would hold it. (I promise I turned power off to thermostat, but still it came on when plugged in.....so I guess I didn't).
I am going to save nickels and get the 30 amp plug converted to 50 amp with appropriate breakers.
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 06-28-2016, 04:06 PM   #5
fonzie's Avatar
normal appliance amp draws
Fonzie
Old 06-28-2016, 04:10 PM   #6
Just to confuse you more, you will have 70 Amps less.
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
Nights camping in 2017: 20 nights
Miles traveled in 2017: 1,530
uhduh camping is offline   Reply With Quote
Old 06-28-2016, 04:16 PM   #7
TURBS's Avatar
If you spend the money on a progressive 50 amp ems you can see how many amp your pulling!
My 15k and 13.5k draws 28 amps.
Remember your converter is a constant 2-8 amps .
Sent from my SCH-R530U using Tapatalk
Old 06-28-2016, 04:18 PM   #8
BandJCarm's Avatar
Turbs, my 50 amp P.I. EMS showed 18 on L1 and about 4 on L2 when it blew the 30 amp breaker in the house..................fyi...........
Also, the digital readout on trailer wall thermostat said "E7"
FROG AR-0019-242
Old 06-28-2016, 04:23 PM   #9
TURBS's Avatar
Yeah when I get home ill take a few pics of both legs and see .
I wanna say l1 was 15 amps and l2 was 13
Old 06-28-2016, 04:26 PM   #10
please no pics of your legs.... or any other body parts...
2015 Ram 2500 4x4 6.4l with 2015 Sandpiper 25RLS
Wife, myself and 2 furry kids
Mountndream is offline   Reply With Quote
50 amp
