Old 07-24-2016, 07:34 PM   #1
50Amp circuit connect to 15Amp house hold.
Brought my new MH home yesterday, under the Texas heat above 100 degrees, my MH interior was extremely baked.
I do not have the 50Amp circuit for the RV at the house yet and was wondering if I could connect my 50Amp RV to the 15Amp house circuit using the adaptors so I could have the power to charge up my batteries so I could use the 2 fantastic fans to suck the heat our of the RV.
Would this feasible? Have anyone done the similar thing?
Thank in advance.
Tam & Ha
Willis, TX
2016 Georgetown XL 352QS
2011 Jeep Grand Cherokee
2016 Nights Camping - 6 nights and 2 shake down and love it...
tamdle is offline   Reply With Quote
Old 07-24-2016, 07:37 PM   #2
fonzie's Avatar
yes you can.......
Fonzie
Nights Camped: 2011(21) 2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36)
Old 07-24-2016, 07:41 PM   #3
Krazymace's Avatar
Absolutely! Might even be able to run 1 AC if not running anything else.
Krazymace is offline   Reply With Quote
Old 07-24-2016, 07:44 PM   #4
Originally Posted by fonzie View Post
yes you can.......
Many thanks to Fonzie and Krazymace for your quick response. I will order the 10 gauge extension cord and the adaptors from 15Amp to 30Amp then to 50Amp to connect this system.
That is great!
Tam & Ha
Willis, TX
Old 07-24-2016, 07:53 PM   #5
Be careful about running the air conditioner though if you decide to do it. As Krazymace said, NOTHING else should be running, including the fridge and anything plugged into the outlets. I did that, and the fridge starting acting flaky. It has since returned to normal, but I won't be doing that again.
Sent from my SD4930UR using Tapatalk
2016 Salem Cruise Lite 261bhxl
Ram 1500 5.7l Hemi Crew Cab 4wd
gspot01 is offline   Reply With Quote
Old 07-24-2016, 07:55 PM   #6
RedLdr1's Avatar
Thank in advance.
I am doing basically that with our motor home. The difference is we have a 30Amp service. I bought a 30Amp to 15Amp adapter, a short twist lock cable to a male 15Amp three prong plug, and plug it in to a heavy duty extension cord to power our rig in the storage lot. I can run the fans, lights and fridge or our one 15,000 BTU A/C unit. Make sure you get a heavy duty extension cord or the power loss / drop may cause you problems.
Wayne
2017 Sunseeker GTS 2800 QSF
TOAD: 2016 Ford Edge Titanium FWD
RedLdr1 is offline   Reply With Quote
Old 07-24-2016, 07:56 PM   #7
Flybob's Avatar
Try to find an house outlet that is not GFCI protected. GFCI's do not play nice if there are two of them in series .
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 07-24-2016, 08:03 PM   #8
swamprat26's Avatar
Just keep an eye on your voltmeter and keep it in the green
swamprat26 is offline   Reply With Quote
Old 07-24-2016, 08:04 PM   #9
Thank for all of your input. My main objective is to have the power to charge up the batteries so it could run the 2 fantastic fans which I am assuming they are both 12volts to suck the heat out of the cabin. Also, I have the small may be 10 cf lp/electric refrigerator that I may want to keep it working so that it will not smell if not use for a while. As far as the air conditioning, I don't think that I would need that since it will suck power like crazy to cool down the coach which may end up burning a hole in my pocket.
Tam & Ha
Willis, TX
Old 07-24-2016, 09:23 PM   #10
360true's Avatar
Make sure your hot water heater is also off. Turn off the breaker....
360true is offline   Reply With Quote
