Old 07-02-2012, 02:27 PM   #1
SEAYALL's Avatar
a/c compressor dripping oil
Greeting
Have not seen much on here about this, 2012 #378 .. 1 year 2 mos. old A/C compressor has drips of oil on bottom both ends. I understand this is not a ford item.
Is there an e-mail or phone number for Mr Armstrong? Or suggestions where to start on this problem .. thanks
SEAYALL is offline   Reply With Quote
Old 07-03-2012, 10:35 AM   #2
I believe the AC compressor is supplied by Ford as part of the chassis, so I would talk to a Ford Truck dealer.
rgfenner is offline   Reply With Quote
Old 07-03-2012, 10:57 AM   #3
TURBS's Avatar
Engine mounted a/c compressor should be ford chassis equipment.
Ford dealer should be ably to take care of it.
Fyi a little seapage is normal when new.
Old 07-03-2012, 04:01 PM   #4
SEAYALL's Avatar
thanks... its has 5500 miles an has developed a drip, sticker on compressor says Sanden Corp an Ford yellow sticker.. i talked to ford they said they research by vin number an its theres, i'm alittle nervous cause sticker for chassiss says a/c prep. i'd like to get a hold of mr armstrong at FR warranties to verify before we get to tearing anything dowm...
Old 07-03-2012, 06:42 PM   #5
Send a message via Skype™ to Falcon35
I have found John very helpful.
He was good at returning emails to me.
I sent him an email in the evening and had one back from him before 8AM the next day
He will want your coaches vin #.
jarmstrong@forestriverinc.com
2012 Georgetown 378TS Fire Mist
2008 Honda Fit
ReadyBrake™ Surge Brake System integrated with ReadyBrute™ Elite RV Tow Bar
Protect-A-Tow
Falcon35 is offline   Reply With Quote
Old 07-03-2012, 08:03 PM   #6
miked11272's Avatar
We had the same problem on our 2009 Georgetown 350 it was fixed under my ford chassis warranty . I called my local ford dealer to see if they could handle the repair. There is also a 1 800 number in the ford warranty guide they will set the appointment for you.
miked11272 is offline   Reply With Quote
Old 07-04-2012, 11:37 AM   #7
oil leaks
when compressor leaks oil you also lose refrigerant. the systems need to be started up in a/c every month year round. if to cold to operate block part of condensor with cardboard to raise discharge psi. seals dry out when not used in rotation over period of time. that will result in leaks.
skipper194242 is offline   Reply With Quote
Old 07-04-2012, 11:59 AM   #8
SEAYALL's Avatar
Yes thank you ... i have run it monthly year round, but your point is well taken, thinking i just got a leaker..
Old 07-05-2012, 09:58 AM   #9
SEAYALL's Avatar
Thanks to all on this thread, wanted to get this out asap, contacted Mr Armstrong, he got right back to me an confirmed the a/c compressor is part of the ford chassiss. So its off to ford.
FYI for anyone traveling in Atlanta,Ga area Mike Fitzpatrick Ford in Newnan,Ga has a lift big enough to handle our rigs,its easy into them an there very egar to help.Service managers name is Scot.
Old 07-07-2012, 12:02 AM   #10
ronhanson's Avatar
This is a good reminder to run that chassis ac every so often. I had a habit of only running roof air and had the same problem with my chassis air at the 2 yr 10month mark. Lucky to be still under warranty.
Ron Hanson
2009 Georgetown 350TS (bunks)
400W solar, 440AH 6V GC2
2009 Ford Edge AWD Ltd towed
2011 Honda Fit Sport towed
ronhanson is offline   Reply With Quote
