So on the passenger side under the dash is an AC tube. Once the AC is running for a while starts dripping puddles of water onto the floor so much that I have to keep a towel underneath it. It seems that it is just from condensation. Has anyone else had this issue?
Here's something to check on, Follow the hose out the firewall and see if it just ends straight out. that was my issue and all that was needed is to fit a right angle on the end of the hose to point down, the air is blowing the water back up the hose and it can't drain.
