Old 09-15-2014, 09:28 PM   #11
Iwannacamp's Avatar
Originally Posted by hazbunch View Post
Sounds like a poor design, but nice to know it isn't the compressor. I have Generac Q65 generator and it will shut off when the oil temp sensor gets to hot. I found out on this site that you should go to straight 30W oil and change the oil temp sensor to the next higher setting. I will update if it works.
Find out who manufactures the engine for the gen set. Use their engine oil specs based on service and temperature ratings...then see if you can find a synthetic oil to meet those specs...buy it and stay with that brand. You do not want to change synthetic oil brands without the proper procedures.
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Old 09-16-2014, 06:24 AM   #12
what are the "proper procedures" for changing brands of oil ?
2014 Georgetown XL 350TS
2014 Jeep Wrangler Rubicon Unlimited
Front & Rear Roadmaster Sway Bars
Koni Shocks
Front and Rear Sumo Springs Jounce Replacement
willingtonpaul is offline   Reply With Quote
Old 09-16-2014, 06:46 AM   #13
Iwannacamp's Avatar
Speaking synthetic oils.... A royal purple engineer told me to not "switch around" with synthetics. Some oils don't mix well and CAN cause jelling type issues. He said if you are changing synthetics to use conventional oil for 1 or 2 oil changes then you can change synthetic oil types.
2017 Puma 297RLSS
Old 09-16-2014, 06:50 AM   #14
A/C recharge on 351
I call BS on that statement. That is just a scare tactic, IMHO.
And i am using royal purple full synthetic 15w-40 in my genset. Love the oil for that use.
Koni Shocks
Old 09-16-2014, 07:07 AM   #15
Iwannacamp's Avatar
Whatever. Never call the hand unless you have done the research.
2017 Puma 297RLSS
Old 09-16-2014, 07:10 AM   #16
i just read the bottle....simple as that....
says nothing of the sort....
or you can go here:
http://www.royalpurpleconsumer.com/r...aqs/motor-oil/
Koni Shocks
Old 09-16-2014, 01:11 PM   #17
Iwannacamp's Avatar
However we do recommend doing a complete drain and fill as opposed to doing a partial top off on top of some other companies oil. We recommend against mixing different product lines or brands of oils from different companies, as it is not considered a best practice. Additive conflicts can occur in some cases when dealing with large quantities of mixed dissimilar engine oils.
Perfect
2017 Puma 297RLSS
