Old 01-07-2016, 10:19 AM   #1
A/C Unit
We were using are 351ds last week down in Florida and noticed water dripping from the white grill/vent. The water drips from the corner of the white plastic grill above the bed in the back. Any ideas on what is causing water to drip down instead of drain out the top on the roof. Anyone know a solution. Thanks.
teamg5 is offline   Reply With Quote
Old 01-07-2016, 11:08 AM   #2
TURBS's Avatar
Coils possibly freezing a little bit.
Do you have vents closed off or are they all open?
Sent from my SM-G900R4 using Tapatalk
Old 01-07-2016, 02:35 PM   #3
Welcome to Florida humidity! If you leave the door open or leave a window open any length of time you have allowed the good ole Florida humidity to get in your RV and then condense on the cold white plastic cover of your A/C. Seen it a hundred times...usually folks from the north who are use to opening windows in the summer.
Lostdog
2011 Georgetown 378TS in FireMist
2013 Jeep Wrangler Toad
Kirby the Old Dog, passed but still in our hearts
Max E. Dog, the new pup
Eureka the Old Cat, still hangin' on
Lostdog is offline   Reply With Quote
Old 01-07-2016, 02:43 PM   #4
No all the vents are open. We didn't have a problem at all this past summer in the humidity so I would be surprised if that is the issue. It may be something is freezing up but I would have thought the warm (87) outside air is hot enough that it would be able to keep the coils from freezing up. Any chance of a drain line being clogged somewhere?
Old 01-07-2016, 02:49 PM   #5
TURBS's Avatar
Nope there's no drain line internal.
If you slightly open the quick cool dump that may help.
Old 01-07-2016, 02:59 PM   #6
Flybob's Avatar
Check the filter. If that is dirty, you will get reduced air flow and freezing up.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 01-07-2016, 03:07 PM   #7
I'm from Florida and have been camping for years here and have learned that I shall never open a window, leave a door open or allow any outside air into our RV when it is warm outside and the humidity is above 60%. When the A/C is on and when it's time to exit I open the door, exit and close the door. No windows open, ever. Cupboard doors will not close right, and the plastic on the A/c will sweat and drip. Just the nature of the south. The only way water can get into the RV from an A/C unit is if there is a leak where the unit is mounted in the 14" opening and if you have a leak there it would also leak when it rained. Keep her buttoned up and I believe that your problem will go away.
Lostdog
Old 01-07-2016, 03:08 PM   #8
TURBS's Avatar
It's also possible the frost sensor fell off.
Old 01-07-2016, 08:25 PM   #9
Ok thanks. I will check the filter and make sure all the doors and windows are shut. Thanks again for all the replies.
Old 01-08-2016, 05:10 AM   #10
cjd10's Avatar
It also helps to run the fan on the high setting to keep condensation from collecting in humid conditions.
2014 Georgetown 351DS
Charleston SC
3 Boston Terriers, 1 Frenchie
Gonna miss you Toby. RIP
cjd10 is offline   Reply With Quote
