Old 07-11-2012, 07:53 PM   #1
Tim & Lisa Trempert
A/C Vents Closing - FIXED
My A/C vents kept closing on their own when the A/C was running. It was very frustrating as every few hours I'd have to go around and open them again. I was worried about them closing and freezing up the compressor. I had it to the dealer and they "adjusted" them (not sure what adjustment there is!) but they still closed. Below is what I did to fix them.
First, I removed the vent by removing some of the louvers and then pulling on the edge. I then put a dab of caulk on the holes that hold the smallest louver. This creates just enough friction that the louvers still open and close, but only when you push on them. To finish things up, I sprayed some lithium grease on a paper towel and rubbed it in the opening so the whole vent would turn to direct the airflow. Some of them had started getting very difficult to turn.
I can now sleep all night, and in the morning the air is still blowing on my face!
ID:	16397   Click image for larger version
ID:	16398   Click image for larger version
ID:	16399   Click image for larger version
Tim & Lisa
2011 Georgetown 350
Trempert is offline   Reply With Quote
Old 07-12-2012, 05:28 AM   #2
Navion IQ 24V
My previous RV, a 2011 Cardinal 5th(Forest River) wheel had the same vents & issue. There was a silent recall on those vents, but we never heard about it from the dealer. I fixed mine by removing the vents then placing a small o-ring on the pivot shaft of the center vent. I takes up the slack in the vent to cause enough friction to keep the it open. No more closing by its self. Oh yeah the dealer did order me a full set of vents, to replace mine but I never picked them up.
Sold 2012 Georgetown 350F Gasser
Navion IQ 24V
Wildhog56 is offline   Reply With Quote
Old 07-12-2012, 06:37 AM   #3
TURBS's Avatar
Orings as stated do the trick.
Old 07-12-2012, 06:27 PM   #4
We started out by placing wood clothes pins, but graduated to using those ornamental weights that clip to a tablecloth to keep it from blowing away. They are decorative and always starts a conversation like "what are those for?"
Lostdog
2011 Georgetown 378TS in FireMist
2013 Jeep Wrangler Toad
Kirby the Old Dog, passed but still in our hearts
Max E. Dog, the new pup
Eureka the Old Cat, still hangin' on
Lostdog is offline   Reply With Quote
Old 07-12-2012, 07:54 PM   #5
mike54's Avatar
all my vents like those fell apart so I put new ones in they work better than the original ones
Mike & Marsha
2011 Signature Ultra Lite 8319SS
2005 Dodge Ram 3500 5.9 cummins diesel
http://www.facebook.com/WestAllisSunshiners
mike54 is offline   Reply With Quote
Old 07-13-2012, 08:58 PM   #6
Freds342's Avatar
And you used? (Why does this feel like pulling eye teeth?)
If you have a solution to a problem, POST IT!
2005 Georgetown 342DS XL, Full Banks Package
2005 Liberty Renegade 4X Toad
1989 Wrangler Sahara Toad
1984 19.5' Beachcraft i/o 5.o liter, 4-bbl (and you thought your Moho sucked gas!)
D/W Carole and Maggie the Teacup Lab (Black Chihuahua)
Freds342 is offline   Reply With Quote
Old 07-14-2012, 06:57 AM   #7
We had the same problem, FR sent new vents, same problem. DW cut small pieces of styrofoam and wedged them between the outer ring and the largest slat . Works great besides we don't close them anyway.
tetsurvivor is offline   Reply With Quote
Old 07-14-2012, 03:01 PM   #8
MOLRMEK
I also have the same problem but after reading your fix with the o rings,today i went to auto parts store and got some o rings and fixed the problom.
George & Marcia
2011 Georgetown XL 337 DS
2005 BLAZER ZR2 TOAD
MOLRMEK is offline   Reply With Quote
