Old 02-19-2011, 10:46 AM   #1
barlin44's Avatar
A dumb question re:378TS
Hi all,
I want to drain the water tank as it is the same water from when the dealer filled it. I found a about a 1" pvc threaded plug in the piping under the tank, however even our old 5th had a ball valve to drain.
Thanks for any info as I am still in the learn as you go phase, but I reckon I will always be in that phase........
Happy adventures,
Barney
barlin44 is offline   Reply With Quote
Old 02-19-2011, 11:12 AM   #2
barlin44: you always has the option to install a drain valve instead of the drain plug. Avaliable at home depot for aprx 6$.
capucine is offline   Reply With Quote
Old 02-19-2011, 06:25 PM   #3
barlin44's Avatar
Thanks,
Yes that is no problem installing a valve, just making sure the plug was in fact the drain as there are several ball valves in the area.
Thanks for your input,
Barney
Old 02-19-2011, 07:26 PM   #4
I have a low point drain, and a tank drain, both on the right side of the propane compartment, sticking out the bottom. both have a ball valve, and the tank drain also has a screw on cap.
akcampr is offline   Reply With Quote
Old 02-19-2011, 07:37 PM   #5
barlin44's Avatar
Never thought to look in that area... that would make sense..thanks
Old 02-20-2011, 08:35 AM   #6
kvtaylor's Avatar
Thats where our drain plug for the low point and tank drain is too on our 08 378. The winter siphon hose and valve is located behind a partition above the propane tank.
Ken and Velda
Dahlgren, VA.
2008 Georgetown XL 378
2010 Ford Escape Limited
kvtaylor is offline   Reply With Quote
378ts
