12-23-2011, 11:00 AM
A little assistance on Cable TV Wiring
Had the bright idea of putting our DVR satellite box in the cabinet above the fireplace in our 378 (2011 model). After hours of frustration I ran a cable direct to the receiver, it worked fine. Found that I could connect to the cable TV inlet in the cord storage compartment, disconnect the cable TV wire for the multi function box in the passenger overhead and jump directly from that to the satellite box and get a good signal.
After a while it dawned on me that the TV Out cable off the multi function switch supplies both the front and rear TV and MUST have a splitter in it. Having some experience in this I also know that a low bandwidth splitter will filter out (or choke off) the satellite signal but pass an over the air TV signal.
Now the question is, does anyone know where this splitter is located so I can replace it with a satellite compliant one. I want to put our other satellite box in the overhead by the rear TV and have a "whole house" set up so I can view shows separate from the front TV but also view shows that are recorded on the DVR in front.
JimF, CWO, US Army Ret, 100% DAV
2011 Georgetown 378TS
2008 Dodge Caliber Toad
12-23-2011, 11:49 AM
Add diplexers to permit dual use of outside CATV jack
Please see the following sketch for adding diplexers to allow using the CATV
cable for both Sat TV and CATV.
For further information talk to someone at Radio Shack or do a search
on Wikipedia, the free encyclopedia
Attached Thumbnails Note The left duplexer is mounted in the rear storage and
the right in the cupboard above above the passenger side.
12-23-2011, 12:10 PM
Moderator
From original post "Now the question is, does anyone know where this splitter is located so I can replace it with a satellite compliant one"
Now the answer, not sure, but most of the campers I have worked on the splitter in a cabinet or wall, near the main Television. Take the wall pate off, and start fishing.
Windrider,
Too many toys, not enough time.
2001 F150 SuperCrew
2002 Jeep Wrangler
1978 Cessna 152
2000 Honda 750 Nighthawk
2008 Work and Play 18LT
12-23-2011, 01:32 PM
Hi ! windrider
I know what the original ?? was. But if you give
some thought to the diplexers you
may avoid having to rewire the existing
splitters & associated cabling.
12-23-2011, 04:16 PM
On my 2011 300FWS, there is a three way splitter behind an access panel which is behind the front LCD TV. I believe this splitter sends output to the Front and Back TV's, and to the TV outlet in the passenger side outside storage compartment.
Hope this helps!
Cheers
Leo Mosley
2011 Georgetown 300S
12-23-2011, 08:06 PM
Thanks for the responses, diplexers would actually create more wiring when the change of one splitter which would do the job. Even if I did use them a signal in the range of the satellite signal would be blocked by the existing splitter and it needs to be replaced in either application. I will start digging in the cabinet where the ab switch is.
Note that the 378TS has the 42" tv mounted over the fireplace and it is free standing. The wiring goes through a wiring loom into the slide and up into the chassis. Runing a wire from the diplexer to the DVR is not possible, the DVR is in the cabinet under the TV.
12-23-2011, 09:07 PM
Hi ! JimF
I to have a 378 and use diplexers (sat tv in both front and bedroom), however FR has a tendency to wire their units in variety of ways. I have attached a TV wiring diagram I obtained from FR. Although it does not provide locations for the individual components it may help you.
Attchment:
12-23-2011, 10:22 PM
2011 Berkshire 390BH
I don't know if my experience will help you or not, but I was able to hook up my Dish receiver by doing the following: I finally got it to work, but not as easy as I first thought. I didn't want to climb up on top of the unit to expose the satellite connection, but wanted to use the input connection in the power bay. After several tests and hunting out connections in the TV cabinet, I finally found where the lead comes in from that bay. There are three coax cables that are attached to the back of the antenna boost plate. One is an out to the splitter to allow all of the TV connections to receive a signal from the onboard antenna. Another one is the signal in from the antenna that is being boosted. The third one (the lower black one on the left side) is the input from the bay. I ended up disconnecting this coax cable, hooking it to an A/B switch and reconnecting one output to the prior connection and the other to the satellite receiver. I then connected the receiver to the TV by using the three "stereo plugs" labeled AUX. I then chose Video input on the TV, and selected AUX on the Smart Box, and success. I can now easily switch from my portable satellite external dish to the antenna input by just choosing the input on the remote. The only thing I had to make a note about was if I happen to hook up to a cable TV input, I will need to move the A/B switch to the opposite side. After all this, it probably would have been easier to put a satellite dish on the roof, but a lot more expensive. Good for now.
I have attached a picture of the back of the power boost switch. Hope this might help.
Craig
Finally completed all State visits in August 2011 with a trip to North Dakota.
12-24-2011, 09:21 AM
Thanks all, appreciate the imput from everone. This will wait a few day, Have A Merry CHRISTMAS !!!!
12-24-2011, 10:05 AM
One last thought, and many thanks for the FR TV wiring schematic and the routing of cables using diplexers. After review of the wiring diagrams it is apparent that they are all based on old technology. I had a Coax in Coax out on our old satellite box but we have upgraded to the latest and greatest satellite connectivity and our satellite box is coax in and HDMI out. Putting the box in the overhead leaves me with no way to connect unless I run an HDMI cable from the overhead to the slide, no easy task. This all makes me wish we had kept the old satellite box, we wouldn't be having this conversation now.
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 374 |
| 43 members and 331 guests |
| 12vdzl, bclemens, bikendan, Borwick, Browndog, Capsfloyd, comox, davepcpowernet, david-o, Fitchy, flynmoose, frfan, Gulay, honda1, huricane, Iggy, Interface Admin, jcoff2003, JoeR, Joseph5410, kixonrt66, lami, MrMeyer, Namchief, NeilM108, newtsx3, NINA, patchman, Pawpod, photog, PrairieBoy, rbq, rexerito, Rsgtivr6, showtime0022, Skippkon, sprayking, SpringerPop, Terier, toclark491, wagon52, WestCoastRV'er, wmtire |
| Most users ever online was 996, 05-22-2012 at 11:04 AM. |
