if you have a 50amp coach, then both will work on 50amp shore power, but if your generator is not large enough(amps), then it may only provide enough power for one at a time...
or, yes, one of your generator breakers has tripped, though it may be hidden behind the generator cover and not exposed, like the main breaker is.... flip the main breaker on the generator and see if that makes any difference.
The Turners...
