Old 07-17-2016, 08:46 PM   #11
Bayouownbeer's Avatar
Sounds like transfer switch is shot. I find mine getting worse with every use. I will be calling them.
2017 Georgetown 364TS
Bayouownbeer is offline   Reply With Quote
Old 07-17-2016, 08:51 PM   #12
AC shuts off when on generator
What you are describing is the transfer switch trying to reengage (A thumping sound). Others on this forum are starting to post they are having the same issue. It seems to be pointing to the transfer switch "dropping out". Of course it will not re-engage until the AC's are turned off.
The reason the switch is cutting out is because of the heavy power draw from one of the AC's, though it should not cut out.
My first guess would be the transfer switch, after that the generator. In rare cases it could be the AC units compressor being bad.
It should still be under warranty so unfortunately I would insist on them fixing it.
By the way, you won't need to check to see if you are getting 110 volt because you will not have 110 volt since the switch is what sends powers those items.
The transfer switch is the device that "switches power" from the shore power cord or the generator to the coach.
Keep us posted when you get it fixed.
2013 Georgetown XL 378
2008 Honda CR-V
wrapperman is offline   Reply With Quote
Old 07-17-2016, 10:31 PM   #13
TheLarks's Avatar
Thanks for all the info. Calling about warranty work tomorrow. Will post any updates
TheLarks is offline   Reply With Quote
Old 07-18-2016, 08:14 AM   #14
Read this post:
Generator Issue?
Exact issue both of you are having. So far, FR has punted on the issue. Bayouownbeer, I'd be interested in hearing the response from Progressive.
________________________
2017 Georgetown 364
2011 Dodge Grand Caravan
Stymie71 is offline   Reply With Quote
Old 07-18-2016, 11:22 AM   #15
Just got off the phone with progressive. They have a updated board that plugs into the generator contact that is suppose solve the issue. They ship them out for free. I left the service guy a message I believe his name is Dennis and he called me back within the hour. This is there number 269.781.4241
Old 07-18-2016, 11:58 AM   #16
Wow! So, they have a known issue? I'll get my warranty info. together and give them a call then.
Thanks for the follow-up Bayouownbeer.
2017 Georgetown 364
Old 07-18-2016, 12:03 PM   #17
I didn't need any info I just told hem I had brand new coach and what it was doing. He had I bunch of reason of why it could be doing that. Which I already knew but siad he has had good feedback on when this board was replaced it solved the issue.
Old 07-18-2016, 12:41 PM   #18
TheLarks's Avatar
Thanks for the info!!
Old 07-18-2016, 05:41 PM   #19
I replaced my transfer switch with a Go Power TS50 and it did the same thing, I'm willing to try their update, but not hopeful it solves it.
2016 364TS
Kevin M. is offline   Reply With Quote
Old 07-18-2016, 05:44 PM   #20
I have it coming so we shall see. I seen few guys replace there's with one that doesn't have contacts. Different type on this forum and have no further issues.
generator
