Old 07-31-2016, 08:53 PM   #41
Originally Posted by Bayouownbeer View Post
Kevin you called for the second new one?
Yes second arrived
2016 364TS
Kevin M. is offline   Reply With Quote
Old 07-31-2016, 08:55 PM   #42
AC shuts off when on generator
Kevin did you take the 4 hex head screws out in order to slide the old board off the contact switch and put the new one on?
I'm sorry my mobile guy installed it as he had to switch back to original transfer switch so I didn't see him do it. Ironically the pro power looks identical I'm thinking progressive makes it as well
2016 364TS
Old 07-31-2016, 08:55 PM   #43
Bayouownbeer's Avatar
Originally Posted by Kevin M. View Post
Yes second arrived
What did you tell them? Being you hadn't tried the first on at that point ?
2017 Georgetown 364TS
Bayouownbeer is offline   Reply With Quote
Old 07-31-2016, 09:19 PM   #44
It didn't work for the other person on here, we are in essence the beta testers.
2016 364TS
Old 08-01-2016, 06:33 AM   #45
Ok thanks was debating wether I should get that second one as well. I hooked my first replace up yesterday and just tested it in driveway for few minutes no issues yet. Will get out on road this Friday. Will update.
Old 08-01-2016, 10:01 PM   #46
Ran it for a hour today with both AC's running on way back from alignment shop. No issues so far.
Old 08-02-2016, 01:04 AM   #47
Nice what was your outside temp?
2016 364TS
Old 08-02-2016, 06:57 AM   #48
90 it was mostly cloudy though.
Old 08-03-2016, 08:44 PM   #49
TheLarks's Avatar
We installed and tested the 2nd replacement board in transfer switch today and it did NOT work either. With generator running air conditioner was turned on and as soon as compressor kicked on the Breakers chattered and arced and generator shut off.
TheLarks is offline   Reply With Quote
Old 08-03-2016, 08:48 PM   #50
[QUOTE=MitchDebbie;1279843]We installed and tested the 2nd replacement board in transfer switch today and it did NOT work either. With generator running air conditioner was turned on and as soon as compressor kicked on the Breakers chattered and arced and generator shut off.[/QUOTE
I have had the breaker chatter and one Ac shut off but never the generator shut down. Generator shouldn't shut off with just a problem with transfer switch. Sounds like you have another issue as well
Old 08-03-2016, 08:53 PM   #51
So far so good for me on board 1. It's 102 outside for last 90 minutes and units are both running ok
2016 364TS
Old 08-03-2016, 08:58 PM   #52
TheLarks's Avatar
Per phone call with Cummins they feel like it is the transfer switch but Cummins is going to test the generator next week.
Old 08-03-2016, 09:05 PM   #53
TheLarks's Avatar
What year model is your RV ?
We have 2015 GeorgetownXL 352. Just bought new. Thinking we might have an older transfer switch ???
Old 08-03-2016, 11:33 PM   #54
Who are you asking?
Mine is in the signature as others are 2016 Georgetown 364TS
2016 364TS
Old 08-05-2016, 06:27 PM   #55
TheLarks's Avatar
Who are you asking?
Sorry if I asked a dumb question earlier ..... I don't see any signature or RV info as you replied. Deb
Old 08-05-2016, 06:34 PM   #56
NMWildcat's Avatar
Unfortunately for those of us that use the mobile app, signatures aren't shown as they are on the web site. I've tried to put the same signatures in both applications but I can't get the mobile one to show up.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
NMWildcat is online now   Reply With Quote
Old 08-05-2016, 06:55 PM   #57
TheLarks's Avatar
Thanks so much for clarifying the signature issue. 😃
Old 08-07-2016, 09:40 AM   #58
I access this from my phone with out the mobile app. Forestriverforums.com
Old 08-10-2016, 09:16 PM   #59
TheLarks's Avatar
Update: Hopefully our generator problem is fixed. Took the coach to Cummins today for load test. On the first load test it worked fine , but fortunately when they called M back to show him the generator was working fine, the generator failed. Then it failed 2 more times. Turned out there was a burned up board in the generator. Don't know what caused this. They said it could have been caused by turning generator on while connected to shore power, or a lighting strike or power surge without the proper surge protector, or turning generator off while air conditioner was running. Would have been nice if the dealer had checked this out before we drove off into the wild blue yonder. Anyway one problem solved!! D
Old 08-10-2016, 09:29 PM   #60
Great thanks for the follow up. Happy Travels
generator
