Old 07-31-2016, 08:53 PM   #41
Originally Posted by Bayouownbeer View Post
Kevin you called for the second new one?
Yes second arrived
2016 364TS
Kevin M. is offline   Reply With Quote
Old 07-31-2016, 08:55 PM   #42
AC shuts off when on generator
Kevin did you take the 4 hex head screws out in order to slide the old board off the contact switch and put the new one on?
I'm sorry my mobile guy installed it as he had to switch back to original transfer switch so I didn't see him do it. Ironically the pro power looks identical I'm thinking progressive makes it as well
2016 364TS
Old 07-31-2016, 08:55 PM   #43
Bayouownbeer's Avatar
Originally Posted by Kevin M. View Post
Yes second arrived
What did you tell them? Being you hadn't tried the first on at that point ?
2017 Georgetown 364TS
Bayouownbeer is offline   Reply With Quote
Old 07-31-2016, 09:19 PM   #44
It didn't work for the other person on here, we are in essence the beta testers.
2016 364TS
Old 08-01-2016, 06:33 AM   #45
Ok thanks was debating wether I should get that second one as well. I hooked my first replace up yesterday and just tested it in driveway for few minutes no issues yet. Will get out on road this Friday. Will update.
Old 08-01-2016, 10:01 PM   #46
Ran it for a hour today with both AC's running on way back from alignment shop. No issues so far.
Old 08-02-2016, 01:04 AM   #47
Nice what was your outside temp?
2016 364TS
Old 08-02-2016, 06:57 AM   #48
90 it was mostly cloudy though.
Old 08-03-2016, 08:44 PM   #49
TheLarks's Avatar
We installed and tested the 2nd replacement board in transfer switch today and it did NOT work either. With generator running air conditioner was turned on and as soon as compressor kicked on the Breakers chattered and arced and generator shut off.
TheLarks is offline   Reply With Quote
Old 08-03-2016, 08:48 PM   #50
[QUOTE=MitchDebbie;1279843]We installed and tested the 2nd replacement board in transfer switch today and it did NOT work either. With generator running air conditioner was turned on and as soon as compressor kicked on the Breakers chattered and arced and generator shut off.[/QUOTE
I have had the breaker chatter and one Ac shut off but never the generator shut down. Generator shouldn't shut off with just a problem with transfer switch. Sounds like you have another issue as well
generator
