Old 07-18-2016, 07:09 PM   #21
MitchDebbie, I have been reading up on this issue. It sounds like it is the type of transfer switch you have (Mechanical relay versus solid state relay) or it could be the generator not putting out enough power.
Your transfer switch is the contact relay type which is susceptible to low voltage condition. Meaning when an air conditioner is starting up and the generator does not put out enough power it can cause those types of transfer switches to chatter.
The only way to tell what is causing you issue is to measure the voltage drop when an air conditioner compressor kicks on.
Sorry I couldn't be any more help. But if you do get your problem fixed please let us know.
2013 Georgetown XL 378
2008 Honda CR-V
wrapperman is offline   Reply With Quote
Old 07-18-2016, 07:18 PM   #22
Bayouownbeer's Avatar
It's low voltage causing it. That's what the manufacture said. The new board is suppose to fix the problem. I won't be using mine for a few weeks but will report back once I have tested the new board
2017 Georgetown 364TS
Bayouownbeer is offline   Reply With Quote
Old 07-19-2016, 02:26 PM   #23
This is the transfer switch I was referring to meaning it didn't have contacts
Old 07-19-2016, 02:53 PM   #24
In our 268RKS, when I start the generator two refrigerators (1 for outside kitchen) and the hot water heater automatically revert to electricity. The AC won't run with the added draw. I switched off the breaker for the hwh & outside refer, set main refer to gas only, and the AC runs fine.
Refers don't draw all that much electricity after the compressors are fired up and have been running for a bit. The wh pulls lots of power.
BradB is offline   Reply With Quote
Old 07-27-2016, 01:05 AM   #25
New board arrived and installed tonight, heading out on Friday so we shall see if this solves it.
2016 364TS
Kevin M. is offline   Reply With Quote
Old 07-27-2016, 08:16 AM   #26
TheLarks's Avatar
New board came in but unfortunately the same bad results. They are sending a different board. Btw Dennis has been very helpful and prompt in returning calls hope his engineers can come up with a solution soon.
TheLarks is offline   Reply With Quote
Old 07-27-2016, 08:18 AM   #27
This new board is the same exc one they sent out first time? I have not installed mine yet. I point being did progressive think it could have been a faulty new board. Sounds like there sending you a board that is side different from that first two correct?
Old 07-27-2016, 08:20 AM   #28
Kevin you put your original switch back in and installed the new board? From Progressive?
Old 07-27-2016, 08:52 AM   #29
TheLarks's Avatar
That was our first board to replace. It was different from the original board.
Old 07-27-2016, 10:21 AM   #30
Yes
2016 364TS
Old 07-27-2016, 10:22 AM   #31
Well that's disappointing
2016 364TS
Old 07-27-2016, 12:36 PM   #32
Correct I understand that what I asking is you siad they where going to send you a second board. Is this second board the same as the first on you replaced or it is different as well?
Old 07-27-2016, 01:16 PM   #33
TheLarks's Avatar
it is the same slot but just made different. Btw The first board made more noise than the original.
Old 07-28-2016, 02:07 PM   #34
NCCoachMan's Avatar
Yes
Kevin, did this solve the problem?
NCCoachMan is offline   Reply With Quote
Old 07-28-2016, 02:17 PM   #35
I'll know tomorrow, however he did send me the new second board.
2016 364TS
Old 07-28-2016, 02:25 PM   #36
Kevin you called for the second new one?
Old 07-30-2016, 12:39 PM   #37
Departed 90 degree weather drove 2 hours and then parked and ran for 4 hours without a problem, both AC's running. This is on the first board he sent me.
2016 364TS
Old 07-30-2016, 01:33 PM   #38
Thanks for update I'll be taking mine out next weekend
Old 07-31-2016, 06:24 PM   #39
Good to hear Kevin M. Once Bayouownbeer tries his out I will give them a call and try it out on mine. My next trip is Labor Day weekend. So I have some time.
________________________
2017 Georgetown 364
2011 Dodge Grand Caravan
Stymie71 is offline   Reply With Quote
Old 07-31-2016, 08:44 PM   #40
Kevin did you take the 4 hex head screws out in order to slide the old board off the contact switch and put the new one on?
generator
