Old 09-24-2013, 02:35 PM   #1
Iggy's Avatar
AC stopped working
Well after just over a year of ownership I started the Georgetown and no AC. Worked on last trip fine before I shut it down.
Today I have fan but no cold air. I tried turning it off and back as well as change the temp knob but still outside air.
I plan on taking it to Ford to see whats up. I was told that the compressor is Fords on the bare chassis so hopefully its a compressor seal or the compressor failed internally.
Can anyone confirm the Compressor is Fords responsibility for my 2012?
I also read recently someone else had a compressor failed and Ford replaced.
Old 09-24-2013, 03:13 PM   #2
2011 Berkshire 390BH
Superchief's Avatar
Iffy,
I recently "lost" AC also. Recharged the system on the low side connector and was back in business.
Craig
Finally completed all State visits in August 2011 with a trip to North Dakota.
Superchief is offline   Reply With Quote
Old 09-24-2013, 03:14 PM   #3
Iggy's Avatar
Originally Posted by Superchief View Post
Iffy,
So did you still have freon in the system?
If it was low it had to leak out some where.
Old 09-24-2013, 04:01 PM   #4
CLASS "A" Senior Member
cfsoistman's Avatar
Recharged mine in July and it's been fine since. I wasn't sure it was ever charged properly. Invested a few bucks in a good set of gauges and added 1 can with stop leak and 1 can of plain R134a and it's held fine since. It's colder than I ever felt before. Loss of refrigerant will make it stop running from low pressure switch. It may have a slow leak, could be through the access cap if not tightened properly and the needle valve isn't tight.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 09-24-2013, 04:18 PM   #5
Iggy,
Last year I noticed oil dripping from my A/C compressor on my 11' Georgetown and called my local Ford dealer they confirmed they were responsible for the compressor and got me up and "cooling" in about half a day so yes it is Ford's responsibility.
concours14 is offline   Reply With Quote
Old 09-24-2013, 04:33 PM   #6
Iggy's Avatar
Originally Posted by concours14 View Post
Iggy,
Thanks I will check next time and see if the compressor clutch is activating. If it is I will add a can of 134a and check. If its wet fromoil I will make appointment to Ford ASAP.
Thanks everyone.
Old 09-24-2013, 04:35 PM   #7
Iggy's Avatar
Did you have to get to the AC line from inside the cab or was it located under the front hood?
I will have to check to see if I can find the low side fill valve and check clutch on AC compressor.
Something is always happening to the Georgetown. I guess it happens to all motorhomes. None are exempt from issues.
Old 09-24-2013, 04:55 PM   #8
If you are going to ad R134 make sure you DO NOT use any type that has a sealant. If you do your A/C warranty will be voided. It is hard to find no sealant R134 at most auto part stores so try Napa or Car Quest or such. All certified A/C shops will use an identifier to see if your system has a sealant in it and will not work on them as the sealant can ruin their equipment. As a former ASE Master mechanic who hates not having someone else work on my vehicles I would let Ford check your A/C system. The sealant in most DIY recharge kits can block up condensers and evaporators making what seemed like a cheap fix very pricey. Just my 1 1/2 cents worth.
Old 09-24-2013, 11:00 PM   #9
Iggy's Avatar
Thanks. Warranty is past except the compressor is still under Ford standard warranty.
Thanks for your remarks and will head for the Ford dealer.
Old 09-25-2013, 08:31 AM   #10
Your welcome.
