Old 08-03-2016, 08:40 PM   #1
Ac won't reset
I tried resetting all the CB in the bedroom which will usually reset my ac to work. This time no such luck. The fan will come on but the ac won't any suggestions. It's a 2007 Georgetown gas class A 340
Vegasmailman is offline   Reply With Quote
Old 08-04-2016, 07:51 AM   #2
Head Rambler
Which A/C make and model do you have? It could be a problem with the thermostat or the control board.
Dometic switches the negative to energize the components and Coleman switches the positive. So I can't tell you which wire to jump to see if it's the thermostat without knowing the make and model.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
