Old 11-18-2013, 12:30 PM   #11
B47
Originally Posted by itat View Post
OC, if you're to get technical here, "hot" is different to each person. Water at 120 deg F might be hot to some and just warm to others. My SIL washes dishes in the sink with water that's "warm" to her, but its too "hot" for me to put my hands in it.
I don't know how hot the water is in my water heater before it kicks in to make it hotter.
To the OP, I like the idea of the remote switch. If I were going to do it, I'd prefer the switch be located next to the switch for gas to the water heater. Maybe I'd use an ON-OFF-ON DPST switch. Your location might save running a lot of wire though.
Do you ever hear someone say "that's too warm to touch" - not often.
Doesn't your water heater kick in when the water in the tank reaches or falls below the thermostat setting?
Old 11-18-2013, 01:13 PM   #12
Originally Posted by OldCoot View Post
Why not just "Water Heater" Why would you want to heat hot water?
Sounds like a male pi**ing contest to me. I bet if you asked 100 people about the thing in the basement that makes their water not cold....I bet at least 75% would say 'hot water heater'!!!
Sargent's Fox Hole is offline   Reply With Quote
Old 11-18-2013, 01:21 PM   #13
Ford Idaho's Avatar
It's Cheese and Macaroni!
Old 11-18-2013, 01:22 PM   #14
I agree, but it still doesn't make it correct.
Note the absence of "Hot Water Heater" in these ads.
Shop Water Heaters at Lowes.com!
Water Heater - Tankless Water Heater, Electric & Gas water Heaters*at The Home Depot
Old 11-18-2013, 02:13 PM   #15
bend302's Avatar
I think it's a geographic thing. Midwest and South seems to say hot water heater although I have an English teacher friend that rants when he hears that.
Iggy, did you keep the breaker in the circuit? If so, did you need extra wire for that connection?
Bill
Life is a journey, not a destination.
2005 Georgetown 359ts
Bill & Virginia, Kentucky
Nights camped in 2011...78 , 2012...73,
Nights camped in 2013...123, 2014 ...101
bend302 is offline   Reply With Quote
Old 11-18-2013, 02:31 PM   #16
Iggy's Avatar
Bill
I just wired from the breaker to the new switch using about 18" of 12/2 with ground romex then use the existing wire from the switch to the heater.
Iggy is online now   Reply With Quote
Old 11-18-2013, 02:46 PM   #17
DAISY BOYKIN's Avatar
I did the same-------------------
Iggy, I did the same mod two years ago. But what I found out is you should cycle the OFF/ON switch several times on the hot water tank ever so often.
The reason is I guess the switch becomes corroded and will lose contact. I found this to be true after 18 months of the mod being performed. My Hot water tank stopped getting hot on the electrical side. After investigating the problem, I found the switch was working but at low ele power.
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is online now   Reply With Quote
Old 11-18-2013, 03:22 PM   #18
Iggy's Avatar
Hi
Yes, those small black switches on the actual heater aren't rated high enough to handle constant uses ON/OFFs. The switch I installed is rated at 20 amps and should easily handle the load of the electric element going on. I'm happy.
Have a great day!
Old 11-19-2013, 06:51 PM   #19
copsuno's Avatar
Iggy, for curiosity sake, what did you do about the elec switch at Water Heater, do you leave it in on position or is it by passed completely? Guess you can tell that electrical wiring is not my specialty.
Logic will carry you from point A to point B. Imagination will carry you everywhere. "Albert Einstein". 2011 Georgetown 360, Bride of 45yrs, and 2014 Chev Equinox toad, what more could you ask for.
copsuno is offline   Reply With Quote
Old 11-19-2013, 06:57 PM   #20
Iggy's Avatar
I will leave the switch on all the time and use the new one to control.
If the small switch gives me problems I will remove and bypass the switch totally. It doesn't hurt to leave the one on the water heater on.
heater, hot water, water, water heater
