Old 12-07-2013, 09:28 AM   #21
I install the switch for my water heater,I check the lugs on the breakers while I had the panel off.Found one that was not tighten at all.Good ideal to check while you are in there.
manvel is offline   Reply With Quote
Old 12-07-2013, 03:05 PM   #22
BillMFl's Avatar
good job iggy
And by posting "hot water heater" you also showed how many nits a nitpicker picks, haha. It must be winter and the shut ins found something to do. 83 here in Tampa today. Would that be considered hot? Not for me but I bet the Canucks staying down here are peeled to their underwear.
BillMFl is offline   Reply With Quote
Old 12-07-2013, 03:45 PM   #23
dcheatwood's Avatar
Originally Posted by OldCoot View Post
Why not just "Water Heater" Why would you want to heat hot water?
My thoughts also. Folks down here say "hot water heater" but my plumber dad always corrected us. Water Heater. Ha. Either way, I love this job and will be doing mine soon. Tried it in wildcat but never got the light to work. ???? This looks easier in the rockwood.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 12-07-2013, 03:45 PM   #24
Witch Doctor's Avatar
Originally Posted by Iggy View Post
I have a 2012 378TS and it only has the 120 volt switch outside at the hot water heater. I know why but still wanted to add a switch inside.
I could use the circuit breaker but they are not meant to be used as a switch.
So I bought a switch light combo at Home Depot and used a small amount of wire.
1. I removed the electrical panel and removed the 3 wires from the hot water heater. (black, white and bare copper)
It was long enough to reach the hole I cut above the electric panel.
2. I added about 18" of romex wire from the electrical panel to the new switch and mounted in the wall with a blue electric box. NOTE:I found all the wiring was with #12 AWG (rated 20amps) instead of #14 AWG (rated at 15 amps) . Good job FR.
3. Now when I want to turn on my electric for the water heater in the morning before showering all I have to do it turn on the switch and the red light comes on to show me it is ON.
I could have located it at a different location but I always try to keep it simple and the present location would be hard to accidently turn it on or off. I plan to add stickers to make it look more professional.
Very easy project for about $10 and an hour of time.
Do not understand FR did it right by using 12ga rated at 20 amps then @ 14awg. rated at 15 amps. The larger the wire the less heat it will produce. I would much more want 12ga. instead of 14 ga. Your breaker works off the appliance amps not the size of wire, a larger gage wire will not get as hot...Sorry but you confused me with that statement. You also have to add in voltage drop. Your voltage will drop less with the larger wire and distance it has to travel....
Coachmen M/H
Concord
2018 / 300 DSC
Old 12-07-2013, 03:46 PM   #25
dcheatwood's Avatar
Thanks for the thought.
Old 12-07-2013, 03:49 PM   #26
dcheatwood's Avatar
I think he said he found 12g and not 14g. That's a good thing, right?
Old 12-07-2013, 03:57 PM   #27
Yes you are right, for some reason I read it as he changed from 12 to 14 ga. I even read it 4 times, I guess I'm getting mush brain as I get older......
Coachmen M/H
Concord
2018 / 300 DSC
Old 12-12-2013, 01:03 PM   #28
I think most in my neck of the woods, WNY State, would call it the hot water tank, or "honey did you turn on the hot water tank heater" IMHO LOL!
sherman12
2011 Georgetown 330TS
Kia Sportage on MasterTow Dolly
sherman12 is offline   Reply With Quote
Old 12-12-2013, 01:45 PM   #29
KMP44's Avatar
Don't hear it called the hot water tank that often, but this time of year, its common to hear somebody say they have to "unthaw" the pipes. I can never resist asking why they want frozen pipes.
And since you mentioned being from WNY - I would take a cheap shot and bet you drink "pop" but that might be going too far off topic...
2017 F-250
2013 Rockwood Roo 23 IKSS
KMP44 is offline   Reply With Quote
Old 12-12-2013, 03:19 PM   #30
B47
I was born and raised in Henrietta, NY (just South of Rochester) and we called it "pop" and all "pop" came in glass bottles and there was a 5 cent per bottle deposit required for each bottle purchased from a vending machine and not returned. That "pop" tasted much better than the stuff today.
Our evening meal was called "supper" also.
heater, hot water, water, water heater
