Old 07-28-2014, 08:28 PM   #1
Tater
Adding Fantastic fan
2012 351ds I would like to add a fantastic fan to the vent in the kitchen area. Has anyone done this or know if there is electric buried up in that area to power the fan?
Philmore is offline   Reply With Quote
Old 07-28-2014, 08:33 PM   #2
Plain Old Member
There should be. Pull the inner shroud off of the existing vent. There should be some 12V wires secured in there. Not sure if they still do, but Forester / Sunseeker used to prewire all vents openings with 12v.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 07-28-2014, 08:37 PM   #3
Tater
Sweet BigJohn I'll try that first. Thanks
Old 07-28-2014, 08:43 PM   #4
Plain Old Member
Did a double take and realized this was a Georgetown. Different plant. But, maybe they do it too. For your sake, I hope there are some wires in there. If not, I would try to feed off of the nearest 12v source, usually a light. Hoping a GT owner will chime in shortly to verify. Guess I should read closer.
Old 07-28-2014, 09:19 PM   #5
kenandterry's Avatar
I added a power fan in the kitchen area of our 2010 Georgetown. Pulled down the plastic ceiling shroud and found a brown (+) and white (-) wire looped in the ceiling from the factory. It's on the same fuse as the power for the bathroom vent. Carry on.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 07-28-2014, 09:25 PM   #6
Tater
Thumbs up
Beautiful!!!
Old 07-28-2014, 09:37 PM   #7
Plain Old Member
Ok. Now I don't feel bad. Thought I might have mislead.
Old 10-28-2014, 08:19 AM   #8
I'm just an old soldier and know nothing about electrical things, so now you know of my limited knowledge. I'm going to buy a new fan for the kitchen, DW is too short to reach the controls for the current fan, i want to know is this simple, just take out the old one and wire in the new one?
tetsurvivor is offline   Reply With Quote
Old 10-28-2014, 08:22 AM   #9
TURBS's Avatar
Is there am existing fan there now?
Turbs
Old 10-28-2014, 08:23 AM   #10
yes, it has a fan but the controls are up on the fan. my coach is a 2011 GT360RB
fan
