Old 03-19-2013, 09:36 PM   #1
E/SA DART
Adding oil?
Anyone have an easy way to add oil to the V-10? filler is located in a very tight spot engineer must have been smoking something. does anyone use a pump if so which pump?
mopargilley is offline   Reply With Quote
Old 03-20-2013, 05:45 AM   #2
CLASS "A" Senior Member
cfsoistman's Avatar
I use a cheapy transfer pump from Harbor Freight. When I change the oil I use this with a 6 foot ladder that has a tray to set the oil on.
Multi-Use Transfer Pump
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
cfsoistman is online now   Reply With Quote
Old 03-20-2013, 08:45 PM   #3
VinceU's Avatar
I bought a calibrated funnel with a 1/4 twist shut off valve at walmart. It comes with a 18" clear hose which is removed. The funnel can be inserted in the oil fill pipe and with your other hand can dump oil in 1 quart at a time. No spills no mess. Six operations and you're done.
Old 03-20-2013, 11:10 PM   #4
E/SA DART
Thanks too you both!
Old 03-22-2013, 07:10 PM   #5
Everytime I put oil in our Georgetown I was amazed that with all the research and technology that Ford puts ito its products that the lowly oil fill tube is not given a second thought. I especially had these thoughts when it would spill. It would have been easy to design a better fill tube.
MikeA is offline   Reply With Quote
Old 03-22-2013, 11:34 PM   #6
E/SA DART
Changed the oil for the first time today and I added a 5/8 id hose to my tranz funnel and poured the 5 qt mobil 1 5w 30 jug + 1 Qt with ease there was a small amount left in hose so I unhooked the funnel and blew the rest in with the hose 30 minutes for total oil change.Thanks for the help everyone.
