Old 12-19-2014, 07:03 AM   #11
chrisbailey13's Avatar
FL Family,
How does the multiplexer connect to the factory monitor?
That connection should be the one used for the new display you installed.
2014 Georgetown XL 352QS
2013-2017 Days Camped-215
chrisbailey13 is offline   Reply With Quote
Old 12-19-2014, 07:09 AM   #12
Fulltime in our Berkshire
KennyGolub's Avatar
Originally Posted by chrisbailey13 View Post
FL Family,
With a wire
But seriously, we would like to know.......
KennyGolub is offline   Reply With Quote
Old 12-19-2014, 11:09 AM   #13
Multiplexer end is a 13 pin connection but monitor end is hard wired.
FL family is offline   Reply With Quote
Old 12-19-2014, 01:55 PM   #14
OK,
Not sure if it is cost prohibitive, but sounds like you need one of the RSV Switchers (RVS-227-3) that would replace the multiplex device.
Old 12-20-2014, 08:28 AM   #15
Thanks. That multiplexer is sim to factory installed one just gives you 2 video outs (vs 1). There was a post about a month ago where someone installed the same monitor but it seems like it was moved or deleted now. It had a picture of the dash area including the monitor with some traffic in the background.
Old 12-20-2014, 07:02 PM   #16
That was probably mine.
But, Since my rig is an 352 the stock monitor is on the Double DIN radio and the multiplexer has RCA outputs instead of the 9 pin DIN plug you have in the 351.
