Old 05-26-2015, 06:17 PM   #11
mud yapster's Avatar
I like it thanks for the info I may make my own. Thanks
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 05-26-2015, 06:36 PM   #12
Krazymace's Avatar
Originally Posted by bmurph44 View Post
When we're in the living area we turn on the rear AC only and use a small fan to move air up front, we do the opposite when sleeping.
X2
Krazymace is offline   Reply With Quote
Old 05-26-2015, 06:43 PM   #13
psgrandpa1, the thermostat may be set to always run. Set it to auto fan. The fan will then cycle on and off with the compressor.
2013 Georgetown XL 378
2008 Honda CR-V
wrapperman is offline   Reply With Quote
Old 05-26-2015, 07:22 PM   #14
Originally Posted by wvphil View Post
Classic coach works on hwy 92 near Lakeland FL makes an attractive cover that replaces your inside plastic ac ceiling mount. This cover is custom made and has its own removable washable filter in it. This cover mounts to the ceiling of your coach in place of the inside plastic grill on your ac. They can cover it in white or off white leatherette material to match your ceiling. I purchased one of these approx three years ago for my previous class A and transferred it to my current 378XL two years ago when I traded the older coach for my georgetown. I am pleased with the results and I'd say it reduces the noise by about 50 percent. Only drawback is you will loose your ability to use the quick cool feature of your ac. ie the cold air will only be blowing out your vents. I can now enjoy TV without having to turn the volume so high the neighbors complain. Now let me warn you they are very proud of this invention and I thought it was overpriced but after purchasing it I do not regret departing with the money I spent. I think I paid around 300 dollars for it to have it shipped to me. I had previously visited their facility while in the area and saw this unique cover and later contacted them and ordered one after getting tired of having to blast the tv to watch. They fabricate these in their cabinet shop and it is well made. I will try and post a picture of mine in a few.
2013 Georgetown 378 XL
USAF retired 2002
Go Mountaineers!!
Interesting. I may have to look into one of those. I assume that they are made in such a way that the intake airflow is not reduced?
jrwalkerpa1 is offline   Reply With Quote
Old 05-27-2015, 04:44 AM   #15
Cheap fix to ac noise
I used "memory foam" mattress pad material cut to fit the under side of the "air dump" vent. Taped it in place with foil duct tape. Reduced noise by about 50%. Like other solutions you are losing the air dump feature and forcing air thru ceiling vents. Sorry did not take pics.....
D. Smith
2015 364TS
foretg is offline   Reply With Quote
Old 05-27-2015, 07:18 PM   #16
Bill & Janet
km5xa's Avatar
Originally Posted by jgahlhoff View Post
I mounted a sound bar to adjust for the noise. Works well
Not sure what I sound bar is. Can you explain this?
km5xa is offline   Reply With Quote
Old 05-27-2015, 07:25 PM   #17
It's a speaker system in a bar form with built in amplifier. Most have Bluetooth , so you can use on other devices. Some have am-fm radio as well. They sell starting at about $60 and go up. You can look up on target, Walmart, or similar stores Then decide the size and $$ you want for your pleasure. Good luck
Jerry. Vietnam vet.
Retired
jgahlhoff is offline   Reply With Quote
Old 05-27-2015, 08:08 PM   #18
BillMFl's Avatar
Roof airs are loud because unlike your house all the noise making components are right above your head! Every RV I have owned was noisy and I am a light sleeper. Pain in the a..
BillMFl is offline   Reply With Quote
Old 05-29-2015, 03:11 AM   #19
psgrandpa1's Avatar
Air conditioner noise... Driving me bats
...excited...we have ordered the item from Fl.
340.00 with tax and shipping
Will report back and send pics
Thanks WVPhil for info
Bryan & Vonnie Mathiesen
...you & me
2012 378
Sent from my iPad
Bryan & Vonnie MATHIESEN
Hollister MO
Retired 2011
2017 SUNSEEKER MBS 2400W
2013 HONDA FIT SPORT
psgrandpa1 is offline   Reply With Quote
Old 06-09-2015, 10:42 PM   #20
Krazymace's Avatar
Wife & I are in Boise tonight. Hit 102 here today. I have both AC's on with Low fan. Much less noise than on Hi or Auto. Watching the Cav's kicking Golden States butt and can hear every word.
air conditioner
