Old 07-25-2014, 09:56 AM   #1
Lorigirl10's Avatar
Air conditioning..
Our bedrm AC is dripping when on! We keep it the temp at 76-78 so it's not extremely cold, and it starts with in 1/2 hr of having it on, any it's a 2014.... 378 georgetown , any suggestions ?
Lorigirl10 is offline   Reply With Quote
Old 07-25-2014, 09:59 AM   #2
TURBS's Avatar
Could be condensation as ours does it when it's humid out.
Also could be a a/c seal leak.
"sabre owners united!"
turbs
Old 07-25-2014, 10:20 AM   #3
Lorigirl10's Avatar
Thx, I'll have him check it out, we r in San Antonio Tx. So yes it's humid!
Old 07-25-2014, 03:55 PM   #4
cjd10's Avatar
Do you leave your fan setting on auto? I always have ours on high during the day and don't have any condensation problems. Just a thought.
2014 Georgetown 351DS
Charleston SC
1 Boston Terrier, 1 Frenchie, Two Siamese
Gonna miss you Toby, Sage, and Izzie. RIP
cjd10 is offline   Reply With Quote
Old 07-25-2014, 04:02 PM   #5
HarrynSally's Avatar
After each camping trip I put a dehumidifier in our TH, every day we checked it and empty it. Keeps everything nice and dry.
HarrynSally is offline   Reply With Quote
Old 07-25-2014, 04:28 PM   #6
abjb's Avatar
Can you get on the roof?
The water should be dripping off the side of your 378.
The cover for the roof part of the AC is easy to get off, the drain hole that lets the water run out on the roof may be clogged.
ab&jb
2012 Georgetown 360
SHE wanted "a new motorhome"
abjb is offline   Reply With Quote
Old 07-26-2014, 08:28 PM   #7
Cornelius's Avatar
If the air filter is dirty it will reduce the air flow and cause condensation to form on the interior parts of the air conditioner. This water will then drip inside the motorhome. Make certain the foam filter is clean.
If you don't want to wash and re-use the foam filter, Walmart sells replacement filter material. It is usually located near the home window air conditioners and costs 99 cents. One package has enough to make several filters when cut to fit the Dometic roof A/C.
2010 Georgetown 373
2013 Jeep Wrangler
Cornelius is offline   Reply With Quote
air conditioner
