Old 05-25-2011, 03:13 PM   #1
jsutherl's Avatar
Air Filter
Has anyone replaced the air filter themselves on your Georgetown? I spent about 30 minutes at it and never did figure out a way to get the filter box open more than an inch or so at the front.
The top of the filter box won't budge. The bottom is bolted into a steel bracket. I'm not sure what to do.
2008 Georgetown SE 350DS BunkHouse
jsutherl is offline   Reply With Quote
Old 05-25-2011, 05:11 PM   #2
CLASS "A" Senior Member
cfsoistman's Avatar
I did it once. You have to unclip the 3 snap-down clips. Grab it on each side and lift the front slightly and push to the rear all at once. The top should move back about 3/4" and then lift. It should come off after that. It's a pain believe me. I replaced the whole assembly with the Banks Cold Air Intake Kit with the K&N Air Filter in it. It's easier to get the top off.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 05-26-2011, 11:41 AM   #3
jsutherl's Avatar
That was the answer. To push back on it to release the rear catches. Thanks!
I hit two auto parts stores and neither had this filter in stock. I'll keep looking.
Old 05-26-2011, 12:29 PM   #4
cfsoistman's Avatar
Glad I could help. I left out the numerous curse words I used. Just figured you'd use your own.
You may need to check out a Ford Truck Center for that filter. I looked for one a couple years ago and didn't find any in my area. I'm sure it's on line somewhere though.
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 05-26-2011, 07:35 PM   #5
kenandterry's Avatar
Sounds like the same guy that designed the "user friendly" air filter cover, is the same guy who designed the location for the oil filler neck for the V-10 engine also!!!!!!!!!!! Not that the placement of ANY of the fluid resevoirs is much better throughout the engine compartment.
I'm thinking the filter is available at a genuine Ford Truck centre too because the Triton engine is a popular model.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 05-27-2011, 09:36 AM   #6
jsutherl's Avatar
The third store I checked, O'Reilly Auto Parts, was able to order one of these filters for delivery to their store in a few hours. So I did manage to get one and install it. I only wonder why I didn't order two.
Old 05-27-2011, 11:25 AM   #7
cfsoistman's Avatar
You have that right. They did us no favors with the locations of the fill tubes under the hood. Just changed the oil last weekend. I bought a cheap transfer pump from Harbor Freight $5.99.
Multi-Use Transfer Pump
I'm sure my neighbors were wondering why I used a 6 foot ladder to change my oil. It worked real well with the shelf to hold the gallon of oil. I pumped in 4 qts and then took 2 qts and poured them into the gallon jug. Then pumped the other 2 qts in. Surprisingly I didn't lose a drop and still have a quart left. I'll probably buy another transfer pump when it comes time to add antifreeze.
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 05-27-2011, 02:35 PM   #8
2Susan's Avatar
Multi-Use Transfer Pump.
Thank you for the suggestions and tips. I am not looking forward to doing this.
2011 Georgetown 320DS new June 2010
days camped in 2010: 61
days camped in 2011: 37 (up to Aug 1st)
2Susan is offline   Reply With Quote
Old 05-29-2011, 03:25 PM   #9
cfsoistman's Avatar
I goofed that should have been the 5qt. container not gallon. Oh well it did work very well.
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 05-30-2011, 09:55 PM   #10
jsutherl's Avatar
What about the belt? I was laying in bed in the motorhome this weekend thinking to myself, "I've never even looked at the belt." It must be behind all those radiators, but I think that it may be too far forward to be accessible from the doghouse. I guess I just crawl in behind one of the front tires?
Who deigns these things? And why do we buy them?
