Old 07-15-2016, 08:39 AM   #1
WhoDoMan
Air intake filter upgrade
It's about time to replace the air filter on my Georgetown 2014 V-10. Thinking about a upgrade to a K & N to increase HP/ Performance. Anybody out there install this? Thoughts? Part numbers complexity? Thanks!
whoDoMan is offline   Reply With Quote
Old 07-15-2016, 09:09 AM   #2
gasman94's Avatar
Did one on my previous class c, Ford V10/2 valve. It was an easy exchange, and I thought that it did make a difference. I have gone with K&N's on all of my subsequent vehicles (cars)
Rich
gasman94 is offline   Reply With Quote
Old 07-15-2016, 05:53 PM   #3
WhoDoMan
Thanks I don't see any other responses so I guess it's not a popular upgrade.
Old 07-15-2016, 05:55 PM   #4
Kenny kustom's Avatar
Go ahead... But it will make no difference
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 07-15-2016, 06:49 PM   #5
Sc00ter's Avatar
Used cotton/oil filters for some time (k&n and fram air hog) but went back to paper after reading about testing that showed better flow rate but substandard filtration and even oil coating the mass airflow sensor causing the engine to run bad. This is usually one of those discussions that people have passion for either way. Google it and make an informed decision.
This is the test I originally read. I also read the oil filter test with great interest.
Air Filtration Test
2015 puma 295bhss
2009 ram 3500 6.7l ctd
Sc00ter is offline   Reply With Quote
Old 07-15-2016, 07:36 PM   #6
gasman94's Avatar
Air Filtration Test
Interesting article. Thanks.
Rich
Old 07-16-2016, 12:48 PM   #7
Try to go with a 'DRY" type filter. The "OIL" type sometimes sets off the the Mass airflow sensor when to much oil is used. Don't know how K&N comes up with their MPG and performance gains. Did they drive a truck from LA to New York using a stock setup then used theirs on the way back?
mike.t is offline   Reply With Quote
Old 07-16-2016, 03:50 PM   #8
Don't know if there's any actual mpg or horsepower gain, but can say that I have used K and N filters in both my 2011 Acura and my 2005 Tundra for over 150,000 miles combined with no problems. I mainly do it for the savings factor when it comes to the cost of buying filters over and over again.
TundraWolf26DBH is offline   Reply With Quote
Old 07-16-2016, 09:48 PM   #9
Filterman's Avatar
Here's my 2€ents worth. I spent 40 years in the filter industry with a company that makes 85% of the air intake systems for Diesel engines in North America.
As a corporation, we had a look at the K&N type technology and spent a lot of R&D dollars on it. We were unable to get the efficiencies we wanted so the program was scrapped . Air filtration is all about maximum cleanliness of air going to the turbo with (efficiency) with the lowest initial restriction when the filter is new and clean. IMHO K&N will slightly reduce your restriction but will not give you the cleanliness efficiency your engine wants. If your running all pavement, minimum fine dust...probably OK. For my $ I stay with the OE system that has had hundreds of thousands of dollars in research spent on it.
Floyd & Carolyn
2012 F150 S/crew 4X4 6.2L 6Spd Tow Max Firestone airbags. 2011 28RKS Wildcat. Yamaha 3000iseb Gen.
2014 57 nights.2015 116 nights .2016 96 nights .2017 72 nights. 2018 157 nights. 2019 52nights.2020/21 118 nights. 2022 115nights
Filterman is offline   Reply With Quote
Old 07-17-2016, 08:48 AM   #10
Not good in dusty conditions
I bought one for my Jeep Liberty diesel. After I read the fine print about not using in dusty conditions, I never installed it. Here in the southwest, it is always dusty.
mnoland30 is offline   Reply With Quote
Old 07-17-2016, 09:00 AM   #11
Toy-aholic
100 % agree!
MAF sensors do not like K & N! Stay with OE
2005 GMC Sierra 3500 SLT DRW 6.6 D/A
2013 Crusader 335BHS TE
EXGMTech is offline   Reply With Quote
Old 07-17-2016, 09:23 AM   #12
WhoDoMan
Thanks all. In this forum it's nice to get others perspective. I'm gonna keep on with the OEM.
upgrade
