Old 08-01-2016, 10:45 PM   #11
toslow's Avatar
i would not be pulling any bolts on the steering if you are not sure whats going on?
haven a blast
toslow is offline   Reply With Quote
Old 08-02-2016, 07:51 AM   #12
waiter21's Avatar
There is no spline shaft on the steering wheel like most cars.
However, As mentioned by Oganfarm, the control arm is splined where it connents to the steering gear box. This arm can be removed and re-positioned just like you would a steering wheel shaft on a car.
You can see the arm (item #9) on this lube chart.
http://2001mirada.com/DOWNLOAD/f-53lubepoints.jpg
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2001 Civic
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
Old 08-02-2016, 09:25 AM   #13
I'm no mechanic either but on my 2000 Allegro with the older F53 chassis I had an alignment done on it. The shop told me since Ford has a solid axle the only way to get a "true" alignment was to bend the axle. This is a well known Ford procedure going back to their Twin I Beam suspension they touted on their pick-up commercials. I mentioned to the shop that the steering was off too and I was told if that's all I want done they could center it quickly for not much money. I elected to have the full alignment done at a cost of $504. Holy crap what a difference it made in the ride and handling of my rig. No typical Ford wander and loosey goosey vague feeling. Straight and tight feeling.
sherman12
2011 Georgetown 330TS
RAV4 on MasterTow Dolly
sherman12 is offline   Reply With Quote
Old 08-02-2016, 10:57 AM   #14
RVnut's Avatar
Originally Posted by rracer5 View Post
X3 on the BS. They're supposed to lock the steering wheel straight then bring the tires/wheels to straight via tie rod & sleeve adjustment at the pitman arm (that's the arm that's attached to the steering box). X2 on find a more reputable shop!
I have done a lot of alignments in my days as a auto mech and that is exactly how you set the steering wheel.. You set the toe with tie rods with steering wheel locked strait ahead
364 Georgetown 2016
in Montana
RVnut is offline   Reply With Quote
Old 08-02-2016, 11:56 AM   #15
This is a truck setup not a car. Set the toe with the tie rod tube. Then if steering wheel is off you pull the steering wheel and center it there. Pulling the pitman arm off the gearbox will not give you the same turning radius in both directions. If you look close the output shaft of the gearbox has a mark that the postman arm lines up too. Also bending the axle only adjust camber, not toe, not caster. Caster is adjusted by shims between the axle and spring. If the shop tells you they can't center the wheel go to another shop, the shop you are using are not familiar with a light truck.
clutchd is offline   Reply With Quote
Old 08-02-2016, 11:59 AM   #16
I too had the same issue before front end alignment. Our mechanic not only corrected the toe in/out and camber but the proceeded to correct the caster. That is what brought the steering wheel straight. The steering wheel was at 10 o'clock but now it is straight as an arrow. My rig now drives straight down the road with just a slight right pull.
2013 Georgetown XL 378
2008 Honda CR-V
wrapperman is offline   Reply With Quote
Old 08-02-2016, 12:04 PM   #17
RVnut's Avatar
I will add many steering wheels have a blind spline so it cant be repositioned plus that will put the steering box off center.. Bottom line the shop did not know what they were doing
364 Georgetown 2016
in Montana
Old 08-02-2016, 01:10 PM   #18
SEAYALL's Avatar
Originally Posted by Bayouownbeer View Post
Went get my alignment done. 1800 miles. Shop told me in order for the alignment to be in spec the steering wheel couldn't be straight. There is no adjustment for just the steering wheel like a car. My steering wheel is at about 10 o'clock going straight. Any one have experience in this. They told me to call manufacture or dealer to see how to straighten steering wheel. Btw it wasn't straight before the alignment but it was about 11 o'clock so wasn't far off.
Take it to ford, I had a Georgetown an they fix it, not exactly perfect but very very close, I used ford in Seffner Fl.
SEAYALL is offline   Reply With Quote
Old 08-02-2016, 01:16 PM   #19
pashooter's Avatar
The Ford F53 steering wheel is splined and can be straightened by removing the cover and the bolt holding the wheel on, and repositioning the wheel. It's part of the front end alignment process. At least according to this.
https://www.fleet.ford.com/truckbbas/non-html/Q59.PDF
2016 Coachmen Pursuit 31BD
2015 Jeep Wrangler Sport Toad
Nights camped in 2016: 23
pashooter is online now   Reply With Quote
Old 08-02-2016, 01:31 PM   #20
X4 or 5 or 6
BBBBBBSSSSS. Find a wheel alignment shop that uses a real mechanic. Centering the steering wheel is a simple process. May take a bit of time but simple nonetheless.
Strigflag is offline   Reply With Quote
alignment, wheel
