Old 08-02-2016, 09:58 PM   #31
Tim & Lisa Trempert
My 2011 had the same problem and the dealer "straightened" it and aligned it.
Tim & Lisa
2011 Georgetown 350
Trempert is offline   Reply With Quote
Old 08-02-2016, 11:20 PM   #32
Bayouownbeer's Avatar
Originally Posted by Strigflag View Post
BBBBBBSSSSS. Find a wheel alignment shop that uses a real mechanic. Centering the steering wheel is a simple process. May take a bit of time but simple nonetheless.
Yeah that's the thing they don't want spend the time
For the cost of the alignment
2017 Georgetown 364TS
Bayouownbeer is offline   Reply With Quote
Old 08-03-2016, 02:42 PM   #33
Originally Posted by waiter21 View Post
There is no spline shaft on the steering wheel like most cars.
However, As mentioned by Oganfarm, the control arm is splined where it connents to the steering gear box. This arm can be removed and re-positioned just like you would a steering wheel shaft on a car.
You can see the arm (item #9) on this lube chart.
http://2001mirada.com/DOWNLOAD/f-53lubepoints.jpg
Thanks for the info this worked.
Old 08-03-2016, 04:02 PM   #34
waiter21's Avatar
You could also pop the steering wheel as someone mentioned, I'm not sure if the steering wheel is indexed or not? (Some cars are), but the shaft is easier. Someone also mentioned that your steering will not be equal, i.e. you can now turn sharper one direction over the other, , but I doubt you will ever notice it.
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
Old 08-03-2016, 07:48 PM   #35
It's a done deal it's straight. There will be no difference I just moved the coupling from the linkage over 2 splines on the gear box
Old 08-14-2016, 04:42 PM   #36
intercept's Avatar
Don't blame the shops or FR. Ford makes the F53 with one solid Tie rod which connects both wheel hubs with one adjustment for toe. The steering box is connected in the tie rod. In most vehicles there are a left and right tie rod so you can make a separate adjustment for each side and center the wheel.
The shops usually center the steering wheel by removing it and centering it on another spline. The amount of shift is not enough to make a difference in the steering operation. Changing the shaft spline position is a also acceptable.
2012 Georgetown 378XL
Toad 07 Lexus RX350
intercept is offline   Reply With Quote
Old 08-14-2016, 05:17 PM   #37
rblattman's Avatar
Before taking possession of my new 335DSF I told the dealer to straighten the wheel. They took it to a Ford service center and had it realigned. No problem.
2016 Georgetown 335 DSF
rblattman is offline   Reply With Quote
alignment, wheel
