Old 01-21-2011, 05:17 PM   #1
nemo45's Avatar
Send a message via MSN to nemo45 Send a message via Yahoo to nemo45
Amana Convection Microwave Removal
Anyone ever remove their amana convection microwave? I'd like to know how its done. I'd like to put a light above the stovetop and need to get into the area above the microwave.
Don & Carol Niemeyer and Sandy
2006 Gulf Stream Tour Master Diesel Pusher
2011 Chevy Equinox Toad
nemo45 is offline   Reply With Quote
Old 01-21-2011, 05:32 PM   #2
Look in cupboard above the micro. You should see two screws. Take them out and the micro tilts towards you. Lift it off the bracket and you are done. Don't forget to unplug it and feed the power cord down at the same time. Best done with two people.
Old 01-21-2011, 10:57 PM   #3
nemo45's Avatar
That'd be a neat trick. There are no cupboards above the microwave in the 378TS. There is no way I can see to access the area above the microwave without going thru the cupboard that is along side the microwave. But, that would entail dismantling the left sidewall of the cupboard. That is why I was asking, in case there was some easy way to get into it, like removing the trim area at the top of the microwave.
Old 03-24-2015, 10:14 PM   #4
I know this is an old post but hoping someone can confirm..
I have the same configuration in my 379XL; no cabinets above the microwave just a 2 inch filler strip.
I am assuming that the only way to access the top mounting screws is to dismantle the side wall of the cabinet to the right where the power cord feeds thru.
Thanks in advance.
Seems as though the magnetron has given up, no heat and a loud humming noise. Anyone else have a similar problem?
livingouradventure is offline   Reply With Quote
Old 03-25-2015, 06:46 AM   #5
bubbles's Avatar
Captured from an IGGY post:
The way to remove the microwave from a 378 is like this.
1. The piece of wood above the microwave is just pushed in place.
It is about 2" high and the width of the microwave.
2. You need to remove this wood by pulling it forward. It may have small staples holding it but it will remove.
I know because mine fell out while travelling and saw the microwave brackets behind it.
The two microwave brackets are screwed in by a few screws and when removed the whole microwave will pivet down. Their is a metal wall bracket that has a lip that it pivots on. Better to have 2 people doing this so it doesn't fall and damage stovetop.
Hope this helps explain how to do it.
Good Luck.
Old 03-25-2015, 05:18 PM   #6
Thanks a bunch!
Exactly what needed to be done, very easy to get out.
