And now the Toad!
Geez! Just when I thought I was eady to go with the "new-to-me" 342, it turns out that I have a tow connector problem!
I "assumed" that a 7 to 6 pin adapter would work for my Toads, and hadn't given it a thought...........until I helped a friend install the Blue Ox set up and wiring on his 2002 Wrangler.
I've probably done 20 Jeeps, from 1970 thru 2003, and never had a problem. The lighting on his 2002 was really screwed when we checked it with my 342, so I pulled my 1989 Wrangler up and it did the same! After scratching our heads for a few minutes, I hooked up my 2005 Liberty Renegade, and it had the same bunch of problems, so I was able (duh!) to eliminate the Toads as the problem.
The Georgetown has a 7-way connector, that going back, is plugged into a 5 or 6-way connector, that plugs into the Ford harness, with some friction tape and stuff in between. Both of my Toads worked fine from the old Georgetown's 6-way, so I bought a 6-to-7 way adapter from my local RV dealer, assuming that all I'd have to do is plug 'n play.
Oh, and the factory looking harnesses have insulation foam all over them, so whatever was done looks factory!
Parking lights: Left light okay, weak right.
Turn sigs: Left okay, right very weak.
With parking lights on, everything changes. Sounds like ground, but can't see where.
More insight: the Liberty has the isolated system, with it's own 1157 lamp in the added socket, and all three act the same.
It's too freaking hot right now to lay out in the sun under the MoHo, so I thought I'd throw this out to the members. Looks like a bad ground, but I have .9-ohms to ground on the 6-pin side of the adapter. That's when my knees started smelling like pulled pork and I quit!!!
Any ideas from y'all? Have at it. Like I said, I quit for tonite before really troubleshooting, but thought someone may have seen this.
And I've just been told that this unit was used as a remote office/dressing room/crew quarters in the entertainment industry.
That kinda explains why nothing of a personal nature was ever installed (even a TP holder!).
2005 Georgetown 342DS XL, Full Banks Package
2005 Liberty Renegade 4X Toad
1989 Wrangler Sahara Toad
1984 19.5' Beachcraft i/o 5.o liter, 4-bbl (and you thought your Moho sucked gas!)
D/W Carole and Maggie the Teacup Lab (Black Chihuahua)
