Old 10-18-2015, 05:46 PM   #1
another dumb tire pressure question
Should you keep increasing the "cold tire" pressure as temperatures drop. I know 85 psi at 70 degrees is different when the air temperature is 50 degrees but after a few minutes of driving the psi begins to climb. I had a blow out a few years ago so correct air pressure is always a concern for me. I appreciate any advice.
tjvpga is offline   Reply With Quote
Old 10-18-2015, 05:54 PM   #2
dcheatwood's Avatar
Good question. I'm interested in replies. I always bring to psi before any trip without considering ambient temp. And check frequently during trips.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 10-18-2015, 06:44 PM   #3
Fulltime family RVer
Each morning before driving, you should check pressures and air up as appropriate. You're right that your 85psi tire at 70 degrees may be 80 psi at 50 degrees.
Old 10-19-2015, 06:58 PM   #4
This how we import (smuggle) cold northern air into Florida. We fill up with 94 psi in the cold north and have to vent the air as we arrive in Florida....
Jim Sullivan is offline   Reply With Quote
Old 10-20-2015, 12:06 PM   #5
X2
Springerdad is offline   Reply With Quote
Old 10-20-2015, 02:20 PM   #6
bend302's Avatar
I add PSI as the temp drops to keep my tires above 80 PSI. They do go higher as we travel but never too high.
Bill
bend302 is offline   Reply With Quote
Old 10-20-2015, 06:19 PM   #7
siskom's Avatar
I also have always filled tires to tire manufacturers recommendation on the tire it will state a psi cold fill it to that and enjoy your vacation. I have never had a blowout towing boats or travel trailers.
siskom is offline   Reply With Quote
Old 10-20-2015, 07:18 PM   #8
Check pressure in morning. Be sure to fill to max psi. Just remember that "ST" tires are rated at a max of 65mph at max psi. Most 15 in. Trailer wheels are rated to 50 psi. Three brands of 16" tires are rated at 75 mph with 10 psi of added air pressure. Heat build up is quickly built up at speeds over 65mph and psi below max. This is what causes most blow outs.
hillsdaletc is offline   Reply With Quote
Old 10-20-2015, 07:46 PM   #9
tire pressure
Over inflation does not blow out tires; underflation always will if driven that way very long.
pdqparalegal1 is offline   Reply With Quote
Old 10-21-2015, 02:19 PM   #10
I have blown out many, many riding lawn mower tires due to not having a gauge and the tire having a slow leak. My guys almost make them rock hard to try to get the day out of them. But after cutting a acre or two they heat up and I get the call "a blown tire".
hugospro is offline   Reply With Quote
pressure, tire
