Old 04-10-2014, 09:18 AM   #1
Antenna booster
Does the 2013 Georgetown XL 378 have a antenna booster and where would it be located? Thanks for your help.
XL 378 is offline   Reply With Quote
Old 04-10-2014, 11:34 AM   #2
bubbles's Avatar
In my 2012 GT 378 it's in the cabinet above the co-pilot on the back wall. It's a standard panel with a 12 volt accessory socket, coax connection, black push button for the booster and green light showing booster is on.
Old 04-10-2014, 04:14 PM   #3
Thanks, I found it but it didn't help me get anymore channels.
Old 04-10-2014, 04:25 PM   #4
You must be in a bad reception area. Our reception normally jumps 2 or 3 bars with the booster on.
2014 Georgetown 351DS
-TruCenter -Front/Rear CHF -Hellwig Links -Tiger Trak -Ran McNally GPS -ScanGauge -Truck Systems TPMS -5 Star Tune
alparmer is offline   Reply With Quote
Old 04-12-2014, 05:16 AM   #5
Retired Ford Tech
Make sure the cable connection at the antenna is tight. I wasn't getting the reception I used too, so I climbed up and the connectors took 2 to 4 turns, much better now. We have the flat omni directional model, it just stays there, no cranking.
rvpezzano is offline   Reply With Quote
antenna
