Old 04-16-2014, 07:32 AM   #11
jojo bamboo's Avatar
thank you, thank you, thank you,
I've got a lot of things to do.
jojo bamboo is offline   Reply With Quote
Old 04-16-2014, 08:16 AM   #12
bubbles's Avatar
You sprayed inside the coax plugs at the antenna with WD40?
Old 04-16-2014, 10:06 AM   #13
WD40 is non-conductive so a short is not possible.
2014 Georgetown 351DS
-TruCenter -Front/Rear CHF -Hellwig Links -Tiger Trak -Ran McNally GPS -ScanGauge -Truck Systems TPMS -5 Star Tune
alparmer is offline   Reply With Quote
Old 04-16-2014, 10:18 AM   #14
bubbles's Avatar
You are correct sir. It is an insulator and that means that an open circuit is possible. Wasn't thinking about a short circuit.
Old 04-16-2014, 10:34 AM   #15
BooBoo23's Avatar
WD stands for water displacement and the 40 is to denote that was the 40th attempt at a formula that would work. It was developed for outer space use. It technically is not a lubricant although WD-40 does make other products at do lubricate but rather a rust preventer.
The purpose was to push water out and replace it with a secret formula of liquid to make it non conductive.
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23 Camped 2015-47
Camped 2016-71, 2017-33, 2018-29 booked
BooBoo23 is offline   Reply With Quote
Old 04-16-2014, 10:54 AM   #16
The way I look at it is that there is enough metal to metal contact on the center conductor and it would take more than WD40 to insulate it.
Old 04-16-2014, 12:18 PM   #17
so, there are no fuse to check on this TV booster?
We all think its the wire or box that has the on off light (that works)
Thanks for all the ideas of what to check,
before I bring it to the RV repair place and suffer all the over priced and incompetent service Iíve come to expect.
I'm gonna have to look for a different repair shop.
I would be surprised if it was something easy and quick to fix.
Wish me luck!!
Old 04-16-2014, 09:36 PM   #18
I had to take my 2006 GT to place that installs stereos and sound systems, they fixed it when my rv repairman couldn't
Sent from my LG-AS730 using Forest River Forums mobile app
jtidaho is offline   Reply With Quote
Old 04-16-2014, 09:47 PM   #19
BooBoo23's Avatar
What did they do to repair it?
Old 04-17-2014, 06:22 AM   #20
Changed the coax ends.
antenna, fuse
