Old 04-17-2014, 06:30 AM   #21
Herk7769's Avatar
Originally Posted by jojo bamboo View Post
so, there are no fuse to check on this TV booster?
We all think its the wire or box that has the on off light (that works)
Thanks for all the ideas of what to check,
before I bring it to the RV repair place and suffer all the over priced and incompetent service Iíve come to expect.
I'm gonna have to look for a different repair shop.
I would be surprised if it was something easy and quick to fix.
Wish me luck!!
That is correct. The fuse only provides 12 volt DC to power your antenna switcher/power supply to the roof antenna. The light tells you the power supply is ON and routing power and signal to the roof.
If both connections on wall plate (front AND rear center) do not work, the coax to the roof or the antenna itself could be shot. (assuming there are actual stations to receive).
________________________________________________
Just a thought, did it work after the switch from analog signals to digital?
You may need to buy an analog to digital converter box if your TV is older than 3 years.
Amazon.com: Mediasonic HW-150PVR HomeWorx ATSC Digital TV Converter Box with Media Player and Recording PVR Function/HDMI Out (Black): Electronics
You may also need to upgrade your antenna with a "Wingman" to get the digital UHF signals in your area.
Winegard - Wingman - Sensar DTV Upgrade
HAM CALLSIGN - KC3FFW
Old 04-18-2014, 09:43 AM   #22
jojo bamboo's Avatar
Thanks again,
I'm in St Augustine Fl now
at a camp site (Bryn Mawr)
TV works good on cable
but not with antenna
When I get home I'm gonna
start doing some troubleshooting
I'll give you a update when I figure out
what the trouble is.
If anybody has any more ideas
please let me know.
I Love this web site
with all this help.
and hope I can help
somebody someday,
....like, pay it forward?
jojo bamboo is offline   Reply With Quote
Old 04-22-2014, 12:18 PM   #23
Well I fixed it.
Bad connection from antenna cable to second cable thatís buried in dicore (thatís that white goop)
at antenna base on roof
I had to dig it out then replaced that short cable, about 5 feet, and new connectors
works very good now.
I saved myself at least $100.00 or more.
Lucky me
Thanks again for all the suggestions, that helped a lot
antenna, fuse
