Forest River Forums
Sunline User Photos
Old 09-22-2011, 06:48 PM   #1
dashonthedash's Avatar
Antifreeze
Does anyone know how to put RV antifreeze into a Georgetown VE (specifically, a 280DS, but the other models should be similar)?
Gary Shapiro
Dash - 12-year-old GSD (aka Shedzilla)
Lily - 9-year-old Greyhound (Racing School drop-out)
Molly - 8-year-old GSD/Husky Mix (Rescue)
2011 Georgetown 29' Class A
dashonthedash is offline   Reply With Quote
Old 09-22-2011, 06:55 PM   #2
Moderator
Are you asking about winterizing the camper, or adding antifreeze/coolant to the engine cooling system?
Sorry if the question seems stupid to do, but you have a motor home, with an engine cooling system.
If you are talking about winterizing the plumbing in the camper part, search for winterize and see if you have any luck.
Windrider,
Too many toys, not enough time.
2001 F150 SuperCrew
2002 Jeep Wrangler
1978 Cessna 152
2000 Honda 750 Nighthawk
2008 Work and Play 18LT
windrider is offline   Reply With Quote
Old 09-22-2011, 06:56 PM   #3
too fast turbo sled
f1100turbo's Avatar
Is there a hose on the suction side of the water pump?
If not buy the kit to do it there.
2005 silverado 2500hd pro ride 5th
2011 palomino sabre 32 bhok-6
2012 arctic cat f1100 turbo limited edition sno-pro
Ron and Amy Benhart
2012 nights camped (5)
f1100turbo is offline   Reply With Quote
Old 09-22-2011, 07:53 PM   #4
Which side is the suction side? I can only access one side of the water pump, the side towards the fresh water tank. On that side is what looks like a small canister with a plastic cap. Know what that is?
Gary Shapiro
Old 09-22-2011, 08:23 PM   #5
too fast turbo sled
f1100turbo's Avatar
the suction side comes from the fresh water tank .
if you have a water filter it is normally on the non suction side of the pump.
the small canister could be a little strainer with a mesh screen ?
Ron and Amy Benhart
Old 09-22-2011, 08:25 PM   #6
too fast turbo sled
f1100turbo's Avatar
after i read your post i have to wonder as well is this for coolant for the engine or to winterize the camper ?
Ron and Amy Benhart
Old 09-22-2011, 10:55 PM   #7
This is for winterizing, and the filter is under the bed. The small canister is directly adjacent to the water pump, in the same position a winterizing siphon would be connected. On the other side of the canister, the tube splits into two separate tubes, each with a valve. The valves must be turned on for the pump to work, but the tubes on the other side of the valves disappear around the tank.
Gary Shapiro
Old 09-22-2011, 11:04 PM   #8
too fast turbo sled
f1100turbo's Avatar
pictures would be great ! that would help tremendously !
Ron and Amy Benhart
Old 09-29-2011, 10:35 AM   #9
A little probing finally cleared up the question, and also finally determined once and for all what the two valves in the water pump compartment are for:
The valve on the left comes from the water tank. The valve on the right is the antifreeze bypass valve. The hose attached to that valve was wrapped around the side of the tank, and I couldn't see what it was until I pulled it out. It is capped, and long enough to insert into a bottle of antifreeze.
Just thought I would post this in case anyone else had the same question. No mention of this is included in the documentation, and I know at least one other poster asked about the valves in a separate thread.
Gary Shapiro
Old 09-29-2011, 01:13 PM   #10
nemo45's Avatar
Send a message via MSN to nemo45 Send a message via Yahoo to nemo45
I doubt if the valve on the right is the waterheater bypass valve. On mine it is the valve to change the pump suction to the line with the cap on it so you can suck from a bottle of antifreeze. The one on the left is to shut off the suction from the water tank. If you try to winterize without bypassing the water heater after draining it you'll be filling it with antifreeze and it will take an extra 10 gal. of anti-freeze. My bypass vavles are accessed thru a white cap under the area where the waterheater is. Its just a matter of opening the one that is closed and closing the one that is open and reversing the proceedure in the spring when dewinterizing.
Don & Carol Niemeyer and Sandy
2011 Georgetown 378TS
2011 Chevy Equinox Toad
nemo45 is offline   Reply With Quote
Close [X]
