Old 02-24-2014, 09:18 AM   #11
camaraderie's Avatar
Thanks...great picture. Wish I could stick my head under a 280 like that but the nearest one is 815 miles away from me...and that is a situation that has applied since LAST SEPTEMBER. It is really discouraging to me that Forest River doesn't require its' dealers to carry at least one of everything...Literally...since last September, you can go from Maine all the way to Florida and only find a few at Lazy Days in Tampa. NO other dealer has them. There are a couple in the midwest...a couple more on the WEST Coast. The dealers within a hundred miles of me will be happy to order one for me. Sheesh. Toyota dealers should try the same thing. "We don't actually stock Corollas' sir...but we'll be happy to order one for you." End rant!
camaraderie is offline   Reply With Quote
Old 02-25-2014, 06:54 PM   #12
Just a short update to close this topic unless someone else has something to add.
I consulted with a professional hitch guy at a major dealership and he advised that he could easily install a class 4 on the coach that would support much more than my anticipated weight. He could NOT guarantee the coach suspension could handle my weight...but Ford has already told me it can. He did suggest I add air bags to the rear to level things out and improve any steering degradation might occur.
My calculation is that the addition of my actual load and carrier will result in about 1000 lbs extra on the rear axle weight... or about 300 lbs more that the class 3 hitch would have put on it. I think I will be well under the GAWR rear of the coach... so this looks do-able.
I'll know for sure when I write the check and get under the coach to see for myself.. but I have a fallback position of using the Swivelwheel system if it doesn't all work out and stick with the factory hitch and a 300lb tongue weight.
Thanks to all who chimed in to help.
Old 02-26-2014, 08:58 AM   #13
undr60's Avatar
I see there is a dealer in New Jersey that claims to have one. http://www.scottmotorcoach.com/inven...wn--280DS.aspx
undr60 is offline   Reply With Quote
Old 02-26-2014, 09:20 PM   #14
Originally Posted by undr60 View Post
Thanks for the find undr60!
