Old 05-30-2014, 12:44 PM   #1
Johnnya's Avatar
Any problem with Back scrapping on road when backing up, or entering gaz station with
I currently own a sunseeker 3010 Class C and upgrading to a GTXL 350. From time to time, my sunseeker rear end (Hitch) will scrape the groud.
Anyone installed some sort of skid roller wheels on your hitch to prevent this?
2015 Georgetown XL 350TS FireMist | Firestone Ride Rite 4 corners air bags | Koni’s FSD Shocks | Safe T Plus | BlueOx Rear Track| 5 Star Tuned | Centramatic's Wheel Balancers | Best handling Georgetown XL Bare None !!!
Johnnya is offline   Reply With Quote
Old 05-30-2014, 12:56 PM   #2
Yours seems to be worse than our Georgetown. I tore off the trailer plug assembly, but the hitch has never scrapped. Not sure how those rollers work. I'm assuming when you bottom out they will lift up the entire rear end.
2014 Georgetown 351DS
-TruCenter -Front/Rear CHF -Hellwig Links -Tiger Trak -Ran McNally GPS -ScanGauge -Truck Systems TPMS -5 Star Tune
alparmer is offline   Reply With Quote
Old 05-30-2014, 01:07 PM   #3
Some pictures would help.
Old 05-30-2014, 02:15 PM   #4
Retired US Army CW4
Tom and Kat's Avatar
I had one of these on my Gulfstream. It sat really low and would scrape on everything.
It worked really well. Itore the 7 pin trailer plug off of my Georgetown the first time I put it in my driveway. Took the mount off, ground everything flush, rewelded the mount on top of the receiver tube and haven't had a problem since.
2014 Georgetown 329DS
Towing a 2011 Jeep Wrangler JKU w/ReadyBrake
Yorkie guard dog on the dash
Tom and Kat is offline   Reply With Quote
Old 05-30-2014, 02:24 PM   #5
So it's the actual hitch receiver that drags?
For me it's the V shaped iron underneath that's actually designed to drag, and boy does it drag!
howzball is offline   Reply With Quote
Old 05-30-2014, 03:07 PM   #6
CLASS "A" Senior Member
cfsoistman's Avatar
Had the same issue as alpalmer. The Shell station just around the corner from me has a terrible slant due to the road being used as a gutter. Took my trailer connector bracket off the first time I turned in. I bought a new trailer connector with bracket and relocated it higher. I cut the remaining metal trailer connector bracket off the hitch and painted it. OI dfon't go there any more because I'm afraid it will rip off the stone guard if I pulled in.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 05-30-2014, 03:30 PM   #7
Old Enough to Know Better
gasman6674's Avatar
I used the roller type on the hitch of an Itasca class c I used to own. They work very well, just let them touch then pull forward slowly. I had to do something similar on my previous V-Cross as I severely mangled the OEM rub guard on my drive
Name:	drag wheel 2.JPG
ID:	53838   Click image for larger version
Name:	drag wheel .JPG
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle.
2020 Keystone Cougar 364BHL ,Gone 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
gasman6674 is offline   Reply With Quote
Old 05-30-2014, 06:54 PM   #8
Johnnya's Avatar
Great info, Thanks guys
Old 05-30-2014, 09:10 PM   #9
This is what I did. I got the wheels at northern tools.
Name:	ImageUploadedByForest River Forums1401502238.714784.jpg
Preadus is offline   Reply With Quote
Old 05-30-2014, 10:10 PM   #10
camaraderie's Avatar
Attachment 53884
Nicely done...did you get the whole assembly at Northern or just the wheels and fabricated the rest?
camaraderie is offline   Reply With Quote
