Old 12-16-2014, 10:37 AM   #11
(Dry Huunday)
DreiHunde's Avatar
Outstanding!
Beau & Sue
FurKid Express
2015 Coachmen Catalina 303RLS
DreiHunde is online now   Reply With Quote
Old 12-16-2014, 04:23 PM   #12
WDK
WDK's Avatar
Really good job!
WDK
WDK is offline   Reply With Quote
Old 12-16-2014, 06:31 PM   #13
Palms's Avatar
This should be pinned. Excellent work!
2017 Forest River Rockwood MiniLite 1905
2016 Jeep Cherokee High Altitude Limited
Thanking the ONE above for the great life here below...
Palms is offline   Reply With Quote
Old 12-21-2014, 12:47 PM   #14
i have the Amana Convection, but would like to do the same thing. I am especially interested in the manufacturer and model number of the outside vent. My biggest concern was the 400 degree plus heat coming out from the convection and discoloring the paint outside.
Paul and Rosemary
2011 Georgetown 378 Firemist
2010 Jeep Liberty Limited 4X4
Maddog378 is offline   Reply With Quote
Old 12-21-2014, 11:24 PM   #15
wvphil's Avatar
I purchased my vent in Myrtle Beach. However, I found the same vent for you on Tweetys. Go to Tweetys.com and type in 50045 in part number search. Item number is N22-0678 made by JR products. price 36.52 in Black and N22-0677 pn 50035 in white.
I have tested mine for 45 minutes at 400 degrees which is my highest oven setting. Vent did not melt. Also I can hold my hand up to the exhaust and it is blowing pretty warm air but does not feel anywhere near 400 degrees being exhausted.
Take a look at new Winnebago's they are venting their convections. The vent they are using is a little smaller so I'm not sure of their part number. I've been told Tiffin is venting their convections at the factory also.
You will also probably need to order an adapter from the manufacture of the oven to vent out rear. (I did anyway) You then will have to use alum vent tape to connect the two together.
I did a lot of looking at different vents before starting. This was by far the best design I could find as far as functional (flapper with latch) and looks (outside cover). There is many complaints with some other designs that the flapper door latches often break. Hope this information helps. Good Luck.
2013 Georgetown 378 XL
wvphil is offline   Reply With Quote
Old 01-06-2015, 02:28 AM   #16
What happens when oven breaks and they dont make the same one anymore?
So when oven breaks you need a new one, but you already have the vent cut out for the old one are you now screwed ?
I talked to forest River and told them after I bought our 378XL if found out it didnt vent out and that this would have likely been a deal breaker for me at purchase if I would have known.
Thanks for your post and pictures and to the person starting the thread thank you too !
dolftb is offline   Reply With Quote
Old 01-06-2015, 03:51 PM   #17
wvphil's Avatar
I'm not overly concerned about finding one to match my hole if mine blows. The convection looks pretty standard and I think with all the manufactures of convection ovens out there I'll be able to find one to match the hole if mine is ever not repairable. The vent is located in the center at the top where the fan motor is located. I think this is pretty standard as far as vent locations for hoods ie microwave / convections. I don't think Winnebago, Tiffin, and other high end manufactures would be venting their coaches if matching the vent hole were a problem. I'd bet the location of exhaust vents in the rear of most convections are pretty much standard. (centered and to the top where the fan would be located) Keeping in mind heat rises I couldn't see a reason for an engineer to design it any other way. But again I'm just guessing as I am not an engineer. I am however an old retired USAF avionics back shop technician and I'm pretty sure I'd get one to fit (one way or another) If I'm wrong on this one the wife may one day be getting a standard oven under the stove or maybe this will be leverage I could use to justify a new diesel pusher. I'll get my biscuits one way or another.
Old 01-23-2015, 09:25 AM   #18
Fireman
Send a message via AIM to dutch
Venting
Wvphill,
Great job, I'm planning to do ours after reading your forums, couple of questions I have is how is the unit being held on, I see four screws underneath one on each corner of the oven is that what holding it? What type of blade did you use on the tool, and when you made the final cut outside did you cut from the inside. Like you pretty scared to cut into the unit but there is a lot of heat that comes out of that when on. Thank for the help.
2013 Georgetown XL 378
Toad 2012 Honda Civic
Dutch & Kathie & shitzue Buddy
US Air Force Retire SMS
dutch is offline   Reply With Quote
Old 01-23-2015, 01:00 PM   #19
wvphil's Avatar
Dutch,
On my unit there is a wooden trim piece across the top of the microwave. Forest river did not take the time to countersink screws and put wooden plugs on top of the screws like some other manufactures. They instead used finishing nails and nailed through the trim to save five minutes labor on their assembly line. I used the hook end of a scribe to hook behind the edge of each side of the trim and pulled it out little by little. I advise removing the other straight end of scribe before you do this so you do not stab yourself in the eye. Once you remove the trim you will see a bracket on Each side of the microwave behind the trim piece with two or three long screws on each side. One side screws into the cabinet area and the other side into the slide wall. It will be easier if you have someone hold up on the bottom front of microwave or prop it with wooden blocks before you remove the screws. Once you remove the screws on the top brackets the microwave can be tilted forward. Tilt it and lift on the back. The main support is the bracket you see still on the wall in my pictures. The microwave has a bracket on the back that does not need removed. No need to remove anything on bottom of microwave. Once you have microwave out use your template you should have in your microwave papers to tape to wall and mark your four corners of cut. You could use a small drill bit to mark your four corners and then a ruler to draw straight lines and connect the dots. I used a new fine tooth multipurpose blade for the multipurpose tool. ( harbor frieight has tool for 20 bucks) direct from china and guaranteed not to last very long but great for this small job. I cut from inside. I went layer by layer through the plywood on the inside wall. Once through the plywood you'll see your styrofoam insulation in wall. Used a box cutter to square off the styrofoam then cut through the fiberglass using the inside cut as guide. You could also go to the outside and use masking tape to square off your four drilled holes and to protect your expensive paint job and cut from outside if you desire. I cut from inside and stood on a small step ladder as the fall would have been not so far as compared to standing on a six or eight foot ladder and falling on the outside of the coach. I've found from past experience whenever my wife helps me with stuff like this one of us normally ends up getting hurt. Keeping this in mind is why I decided to cut from the inside rather than risk my life that she'd hold the eight foot ladder sturdy and cut from the outside. Guess just depends on how much life insurance your wife has on you and who will be holding your ladder steady as to which approach you decide to take. This job really is not very hard to do and if you can cut a straight line after marking you will have no problems. I highly recommend using the same vent that I used as the flapper door is of reasonably good design and should hold up for the long haul. I looked at some other vents that the doors looked pretty flimsy. I suggest you order the adapter that fits on the back of your microwave listed in owners manual. Once you slide this on it will fit into the inside of your coach mounted plastic vent and then you can use aluminum tape to seal from the outside once microwave is reinstalled. The plastic vent has a snap on cover once you mount the plastic vent from outside. You will need some putty tape to put under the lip of the plastic vent to seal around your cutout on the outside. The vent was installed with standard square head self tapping rv screws you can get from any rv parts shop. I pre drilled the holes from outside as I was a little concerned about drill slipping off the screw head and putting a big ugly gouge on my paint. Again, based on past experience, I hope for the best but always prepare for the worst. Hope I've answered your questions. Once you do this mod I promise you'll be glad you did. It Definately should have been done in Elkhart Indiana before these units ever left the factory. If anyone from the company reads these threads I hope they will consider the extra ten or 15 minutes in labor cost it would take to install this vent would be worthwhile. It's the small things like this that keeps the customers coming back to the guy down in Alabama.
Old 01-24-2015, 02:17 PM   #20
Fireman
wvphil,
Thanks for all that information, I really think I can do that now from your step by step, I let you know how I made out,
378xl, vent
