Old 09-28-2013, 07:53 PM   #41
intercept's Avatar
Amp is in the Passenger side top cabinet over the dash on the back wall behind the sound system in the dark in the 378.There is a push button in/out. One position the amp is on and roof top antenna connected. Other position the amp is off and external cable connection is made. In addition to getting this in the right position the switch box on the sound system/dvd player needs to be selected to the correct mode.
FR has too many cooks.
intercept is offline   Reply With Quote
Old 09-30-2013, 07:31 PM   #42
Read an electronics review somewhere and it said the omni directional will not get as good a reception as a directional because the same "energy" is focused 360 degrees instead of 15. hell if I know what that means. Anyway my trailed had the wingman. I just replaced the head with the "jack" I gained 6 stations! I now have 10 stations including the majors ABC/NBC and CBS. Took 5 min. to install. very happy so far.
David 01 is offline   Reply With Quote
Old 10-05-2013, 01:25 PM   #43
abjb's Avatar
Originally Posted by intercept View Post
If you have an I phone there is an app that is called TV Towers USA.
it is either free or 2 dollars. It shows you the tv towers and has an antenna pointer on your location dot. You point the phone to the towers and position the antenna the same as the phone. It is a very handy app to have with the jack.
BTW
The flat end of the jack is the front and the pointed end is the back.
There's an app for everything.... Except when the little boys and girls in Washington are having a spat.
The FCC is down SsOo no tower info.
2012 Georgetown 360
SHE wanted "a new motorhome"
abjb is offline   Reply With Quote
Old 10-05-2013, 02:11 PM   #44
phat phrog stunt crew
there will be an app for that, available in '14
dwaynerz is offline   Reply With Quote
Old 10-05-2013, 04:08 PM   #45
abjb's Avatar
YEP!!
If your title starts with "incumbent."
Congratulations you've been promoted to Common Citizen.
2012 Georgetown 360
Old 10-05-2013, 04:38 PM   #46
Average Joe
MrJoe's Avatar
Originally Posted by abjb View Post
YEP!!
Joe and Karen
2014 Sunseeker 2450sf
Southern Maryland and Beyond!
MrJoe is offline   Reply With Quote
Old 10-05-2013, 05:57 PM   #47
mTn_biKer65's Avatar
Hi David, Any chance we can get a pic or description of your switch? I'm suffering the same disappointing performance from my new 2013 uni-directional antenna to my previous TT with a crank antenaa. It's not a big deal so I was just going to put up with the reduced reception but if there's a 5 min. fix out there it might be something to consider.
Paul
Nights camped
2007 Shamrock F19 hybrid - 2010 (22 nights), 2011 (24 nights), 2012 (11 nights)
2013 Surveyor Select 235RKS -
2012 (6 nights), 2013 (32 nights), 2014 (26 nights), 2015 (37 nights), 2016 (14 nights)
mTn_biKer65 is offline   Reply With Quote
Old 10-08-2013, 07:21 PM   #48
Cornelius's Avatar
An Update: I went ahead with my plan to install the RCA ANT 751 residential antenna on a short wood pole attached to the rear ladder on the Georgetown when we are parked for a while. It was a day and night difference compared to the omnidirectional Winegard TV antenna. The coax cable simply connects to the cable TV input in the read compartment, no amplifier is needed. The antenna disassembles quickly for storage when we are traveling.
Cornelius is offline   Reply With Quote
Old 10-13-2013, 11:50 PM   #49
Ordered my Jack Black HDTV with SureLock
Couldn't wait and just purchased online the Jack antenna OA8201 to replace my flat flying saucer FR installed. Should be here by next Friday and will install with pictures. Picked it up for $116
ID:	41063   Click image for larger version
Old 10-19-2013, 05:52 AM   #50
BillMFl's Avatar
Well I have the old fashion crank model. Other than having to remember to crank it back down when leaving, it works great. Pulls in a beautiful HD picture and in some urban areas I get more than 30 channels. All the usual networks plus a bunch of religious and Spanish stations that I didn't even know were out there and never watch. We have cable at home and truthfully even with several hundred plus channels, other than weather and news, there isn't much that is worth watching. Vampires, zombies, dumb comedies with canned laughter. Mostly junk.
BillMFl is offline   Reply With Quote
Old 10-22-2013, 03:30 PM   #51
If anyone wants a review and pictures of my install of the Jack antenna follow this link.
http://www.forestriverforums.com/for...nna-49816.html
antenna, roo, roof
