Old 03-13-2016, 07:08 AM   #11
Originally Posted by 360true View Post
George's... 4days! Do you have the 4 12 volt batteries? What is your voltage reading after 4 days before you charge them again?
Yes, I have 4 12 volt batteries. The battery monitor will be on the last light before I start the generator to recharge them. My lights have never gone dim so I guess there is still enough volts left. The Refer draws very little to keep it cold once it is already cold.
Georgetown XL 377TS
USAF-- CMSGT Retired.
georgew48 is offline   Reply With Quote
Old 03-14-2016, 10:54 AM   #12
Four days is quite remarkable considering many with residential fridges talk of having to run the genset after just 24 hours.
sherman12
2011 Georgetown 330TS
Kia Sportage on MasterTow Dolly
sherman12 is offline   Reply With Quote
Old 03-14-2016, 11:09 AM   #13
On my previous camper, a Cardinal 5th wheel with a large residential refer, I could go 48 hours with a single 12 volt deep cycle battery without having to recharge or hook up to the truck.
Georgetown XL 377TS
Old 03-14-2016, 01:14 PM   #14
I have a LP/electric fridge in the 5er and have been off grid for over a month at a time without having to refill a propane bottle. Frig use of the LP is VERY minimal. As for the LP HW, if off grid I only turn it on about 30 minutes before showering or doing dishes, then off. Never had an issue running out of propane except when running the furnace. My 5er has a gasoline 5.5 Onan and generally about 2 hours a day keeps dual 12v battery bank up. We do that in the morning, while making coffee, and in the evening while using the microwave. When possible, we make that concurrent with need HW so that water is heated electrically.
I don't have a tankless HW heater so can not speak from experience, but based on the posts I've seen, even when acceptable there is still more water use/waste than with the tank models. Fresh water and holding tank levels are critical when you are off grid.
May have to settle for the residential fridge to get a coach I would have, but that means 2 more batteries, replaced every 2.5 to 3 years at $100 each, OR, higher end batteries every 5 to 6 years at $200 each, plus you NEED auto-start for your generator and that's another, I would guess, $500 or so, unless you have a higher dollar coach that comes with it.
If you're doing most of your "camping" with hookups I see no problem with tankless H/W, other than those posted in several hundred posts, and residential fridge. But, we have always enjoyed the off grid parks and prefer not to be confined, or concerned, about campground facilities, other than enjoying the beauty of the setting. I don't have a problem with those who prefer tankless and residential, just with the manufacturer's who don't allow alternatives.
We also have a Sunseeker "C". Have had Jayco's in the past (a little better quality IMHO) but they've gone tankless on all Greyhawks and class "A's", and thus crossed off our list.
RubberNail is offline   Reply With Quote
Old 03-15-2016, 09:24 AM   #15
Nice post Rubber Nail
sherman12
Old 03-17-2016, 10:04 AM   #16
Originally Posted by daddio View Post
Yes mine is doing the same thing, I hope we can find a solution?
OK took Motorhome back to dealer yesterday to work on several problems and the refrig. was one of them.They checked the refrig.everything seemed to be working but the LP side would not cool the refrig.They FOUND the MFG never cut holes at the top of refrig. cabinet so it would vent thru the roof. said they had to pull refrig. out,cut the holes,etc. Now all's well. Now my motorhome is a Fleetwood, not Forest River but same refrigerators.
Mark1 is offline   Reply With Quote
electric, gas, refrigerator, select
