Old 07-10-2014, 01:23 PM   #1
Johnnya's Avatar
Anyone using Shoreline reels ?
I was wondering if anyone here is using the 50 Amp electric Shoreline reel in theire Georgetown.
The stock 50 Amp cable is pretty stiff and not the easiest one to store neatly in the compartment.
If someone did installed this reel, did you had to reinforce the wall or floor structure ?
Johnnya is offline   Reply With Quote
Old 07-10-2014, 05:35 PM   #2
I converted our Anaconda into an extension. Get one each female and male connectors and cut the cord close to the converter. You can then unplug it from the basement, drop it through the portal and store the hose wherever you want. No more feeding the entire thing through the portal. Probably one of the best mods yet.
2014 Georgetown 351DS
-TruCenter -Front/Rear CHF -Hellwig Links -Tiger Trak -Ran McNally GPS -ScanGauge -Truck Systems TPMS -5 Star Tune
alparmer is offline   Reply With Quote
Old 07-10-2014, 08:51 PM   #3
Johnnya's Avatar
I might just do that!
2015 Georgetown XL 350TS FireMist | Firestone Ride Rite 4 corners air bags | Koni’s FSD Shocks | Safe T Plus | BlueOx Rear Track| 5 Star Tuned | Centramatic's Wheel Balancers | Best handling Georgetown XL Bare None !!!
Old 07-10-2014, 10:04 PM   #4
i wanted to have an extra 30' 50 amp cord....so i just do it that way....let's me put the surge protector in the storage compartment, too, so it's safe and dry.....
2014 Georgetown XL 350TS
2014 Jeep Wrangler Rubicon Unlimited
Front & Rear Roadmaster Sway Bars
Koni Shocks
Front and Rear Sumo Springs Jounce Replacement
willingtonpaul is offline   Reply With Quote
Old 07-11-2014, 09:09 PM   #5
CLASS "A" Senior Member
cfsoistman's Avatar
Summer time I use the coach cable - When it gets cold I leave the cable coiled up in the compartment and use the extension cord, I picked up at CW on sale along with a $10 email coupon. I feed it up through the bottom and plug the coach cable into it. The extension cord is way more flexible in cold temps then the coach cable. Wish FR would look at a better quality cord. My original cord was replaced under warranty when the plug molded end pushed off the cable leaving a 1/2 inch gap. I was told they had numerous problems with the cord ends seperating by the dealer. The replacement looked like it was made by a different vendor. It has stayed together, but it's still like trying to coil up a pool cuestick in that small compartment.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
cfsoistman is online now   Reply With Quote
Old 07-12-2014, 11:07 AM   #6
RudysWorld's Avatar
On another thread someone said they used one of these:
100 Ft. Steel Air Hose Reel
An inexpensive option if it works. Good Luck!!
Rudy - 10 year old long haired dachshund, RIP
2011 Georgetown 350TS
2013 Chevrolet Equinox toad
RudysWorld is offline   Reply With Quote
Old 09-22-2014, 10:25 AM   #7
gmann55's Avatar
How do you hang it on the wall. The wall seems to pretty thin.
gmann55 is offline   Reply With Quote
Old 09-22-2014, 07:45 PM   #8
Johnnya's Avatar
I've used an aluminum plate for re-enforcement, works like a charmClick image for larger version
Name:	ImageUploadedByForest River Forums1411433125.744796.jpg
Old 10-09-2014, 08:50 AM   #9
gmann55's Avatar
Hey Rudysworld! Did the hose real work for you? Did you have to cut the cable and make it like an extension cord? How long is your cable?
Old 10-09-2014, 01:58 PM   #10
RudysWorld's Avatar
Gman55 I haven't tried the reel. The only time getting the shoreline back in the compartment is difficult is during cold weather and I have not convinced myself that the reel would help. I would be interested in others feedback, but don't want to hijack the thread.
