Old 12-06-2015, 12:45 PM   #1
Arct Pac, winterizing and light
Turned on arctic pac and button didn't light up. Does that mean anything? Hope it doesn't mean the arctic pac isn't working! We haven't winterize our MH....have had it for 3 years and it's stored outdoors. We have it plugged into a 20 amp and arctic pac is ,"on" and we also leave the heater on set at 45 degrees. Nothing has ever frozen. We live in the South and our winter aren't cold. We had a few days of low teens and twenties but it then gets up to mid 30s and 40s. It's supposed to be colder this winter. Not winterizing....I hope we don't get frozen pipes!
Lvnlife1973 is offline   Reply With Quote
Old 12-06-2015, 01:03 PM   #2
Witch Doctor's Avatar
Your light might just be burnt out. have you you checked the voltage at the switch going out?
Coachmen M/H
Concord
2018 / 300 DSC
Old 12-06-2015, 01:03 PM   #3
Iggy's Avatar
I'm believe the light should light when the switch is on to tell you that you have power.
If the low outside temp gets below 44 degrees which is monitored by a thermostst oustside will then turn on power to the heat pads to the tanks and any others you may have.
When the outside temperature reaches 64 degrees or the tank thermostat hits 64 it should turn off.
If you do not get a light it may be bad or you may not have battery 12 volt DC power to the switch or the pads. You can check using a DC meter at the switch or you can also check the fuse in your rig. Here is a picture of my 12 volt fuse panel and its marked for Artic Pack. Mine is on a 20 amp yellow fuse.
Iggy is online now   Reply With Quote
Old 12-06-2015, 05:16 PM   #4
The high today was around 70 degrees, so even though it's turned on inside, it won't actually activate because its too hot outside? I looked in the wrong area. I was looking at the switches next to the fuse box.
Old 12-06-2015, 05:43 PM   #5
Krazymace's Avatar
Why don't you just drain your tanks?
Krazymace is offline   Reply With Quote
Old 12-06-2015, 09:20 PM   #6
My arctic pac light didn't light up either. Discovered the fuse had never been installed at the factory.
2011 Georgetown 378 towing 2011 Chev HHR 2LT
ohiobill is offline   Reply With Quote
Old 12-06-2015, 10:04 PM   #7
[QUOTE=Krazymace;1051400]Why don't you just drain your tanks?
Good question....is that where you find the two drain plugs and open them?
Old 12-07-2015, 12:17 PM   #8
Send a message via Yahoo to carluv
Check fuse, they had mine installed in the wrong spot.
carluv is offline   Reply With Quote
Old 12-07-2015, 04:54 PM   #9
Well that's about the norm...
Coachmen M/H
Concord
2018 / 300 DSC
Old 12-09-2015, 08:49 PM   #10
We have the 2006 340 TS that we purchased as the 3rd owner. I see the Artic Pak light on the panel but no switch. I am assuming that we may not have the package installed? Any one ever have them installed after the unit left the factory; at the dealer or DIY?
BuckeyeJoe is offline   Reply With Quote
light, winter, winterize
