Old 01-07-2014, 09:55 AM   #1
Arctic Pac
AAARRGGG. Got down to 18 degrees last night. Turned the Arctic Pac on for the first time ever and nothing froze but I don't know if it is working. The question I have is: Does the Arctic Pac switch light up when on? Ours did not. If it is suppose to light then I've some trouble shooting I need to do. Thanks.
Lostdog
2011 Georgetown 378TS in FireMist
2013 Jeep Wrangler Toad
Kirby the Old Dog, passed but still in our hearts
Max E. Dog, the new pup
Eureka the Old Cat, still hangin' on
Lostdog is offline   Reply With Quote
Old 01-07-2014, 10:24 AM   #2
NELA
Weezer's Avatar
Not sure what I'm going to describe is the "artic pac" but I just went out to check our 5er and on the panel is a rocker switch for "tank heaters". I flipped it on and the rocker switch itself lit up (blue light) and I heard a fan come on.
(We're not using that, as we're fully winterized (pink stuff) and with outside temp of 28, it's 41 in there with only a small ceramic heater going in it.)
If age is a state of mind, and I've lost my mind, I'm AGELESS, right?
Give me 40 acres and I'll turn this rig around:
Flagstaff 5er 2014 8528 IKWS, Platinum Package, Regency Interior "Buffy"
F250 Super Duty 2013 Tuxedo Black "Biff"
Days camped 2014: 30
Weezer is offline   Reply With Quote
Old 01-07-2014, 10:35 AM   #3
bubbles's Avatar
I believe the switch does not illuminate when on. I think the artic blankets do not apply heat till the temp gets below about 40 deg. The switch is the same as the water pump in that it is not imperative the switch be off. Therefore a warning or notification indicator (light) is not needed. I think this is correct. There is no fan associated with your arctic pack, just heated blankets throughout.
Old 01-07-2014, 11:35 AM   #4
when i turn on my switch i get a blue light. I dont think that means anything is actually work other than ther is power to the switch.
2013 Ram 1500 (5.7)
2014 Rockwood Mini Lite 2104s
http://i307.photobucket.com/albums/n...ps412bc14c.jpg
Prothos is offline   Reply With Quote
Old 01-07-2014, 11:43 AM   #5
ramair's Avatar
on my 378 XL the artic pac light does light up, however my light went out but the heater still works. take the panel out and check with volt gauge when turned on see if there is voltage going out. if so the light is out, but everything else is working.
Andrew & Donna Reyes
2012 Georgetown 378XL
2015 Ford Taurus
Our Baby Dachshund
Cammie
ramair is offline   Reply With Quote
Old 01-07-2014, 11:52 AM   #6
Our tank heater switch turns on a Blue internal light when (ON). The fan that (Wheezer) heard was probably the converter fan coming on from (12V) load. Youroo!!
youroo is online now   Reply With Quote
Old 01-07-2014, 11:53 AM   #7
jtrader's Avatar
Wow 18 isn't bad. We got down to -9 yesterday. No arctic pac on ours. Just a lot of insulation and heat tape on our water lines.
My TT: 2013 Cherokee Grey Wolf 28BH
jtrader is offline   Reply With Quote
Old 01-07-2014, 12:15 PM   #8
CLASS "A" Senior Member
cfsoistman's Avatar
Sigma A1 Series Rocker Switches.pdf
The switch will illuminate to indicate the circuit is hot. The heat pads turn on & off by the in-line thermostat outside as long as the switch is energized. I will tell you the bulbs aren't the strongest thing. I've replaced at least 6 over the years. Same switch is used for the porch light, steps and water pump. All are 12 volt. I switched up the color on my artic pac to amber so I know whether on not I had it on at the same time as the water pump which is red and directly next to it. I found the switches on eBay at 1/2 the price of the dealerships.
http://www.ebay.com/itm/Red-15a-12v-...ht_2664wt_1120
Best way to save $ is look for more than one.
http://www.ebay.com/itm/Illuminated-...0#ht_50wt_1120
I bought 10 for $13.90 about 2 years ago but I heven't seen that type of listing since.
Be sure you get 12 volt type because the 120 volt switches look the same. The switch will work but the bulb will not light up.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
cfsoistman is online now   Reply With Quote
Old 01-07-2014, 12:52 PM   #9
We had a wind chill factor of -41* last night. At 18* we would be out grilling. LOL.
Ours lights up when switched on.
2014 Georgetown 351DS
-TruCenter -Front/Rear CHF -Hellwig Links -Tiger Trak -Ran McNally GPS -ScanGauge -Truck Systems TPMS -5 Star Tune
alparmer is offline   Reply With Quote
Old 01-07-2014, 01:01 PM   #10
Denver, CO
garbonz's Avatar
The converter fan should be a good secondary indicator the the heaters are on if it is cold out. At 7 or so amps per pad, they will be a significant draw on the batteries, and enough pull on the converter to engage the fan, I would think. Checking the amperage being drawn would be another way to find out...
2017 Fuse 23T
