Old 02-03-2011, 10:06 PM   #1
Artic pack
Hi,I have a 2011 Georgetown 300 motorhome.Can anyone tell me how the artic pac works?
Inspector is offline   Reply With Quote
Old 02-03-2011, 10:08 PM   #2
Send a message via Skype™ to scubieman
More insulation, bigger heater, double pane windows. Heated tanks. Maybe more yet
2009 Dodge Ram Mega Cab 2500 6.7 cummins
2011 Forest River Cherokee 28BHKS
scubieman is offline   Reply With Quote
Old 02-04-2011, 06:22 AM   #3
CLASS "A" Senior Member
cfsoistman's Avatar
In regards to the tank heaters. They are thermostatically controlled once turned on. They are mounted on each tank and any elbow of the drain system where liquids fill the pipe. At around 40 degrees they come on and will keep the liquids from getting cold enough to freeze. Once above that temperature they cycle off. They are 12 volts so if you're not connected to shore power they are a drain on the coach batteries.
And as stated above the other components come into play as well.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 02-04-2011, 12:29 PM   #4
Artic Pac
Thanks,I found our book on the artic pac.We are in south Texas and have our motorhome in storage.We had freezing temps last night so we drained the tanks which was good because we lost electric.But now we know how the artic pak works.Have you actually had to use yours?
Old 02-04-2011, 01:02 PM   #5
cfsoistman's Avatar
Yes, we went camping in Western MD the second week of November 2010 and Temps were in the low 20's at night. I've used it a couple times as a precaution at the end of the season before winterizing.
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 02-04-2011, 01:17 PM   #6
Anacortesians
According to the documentation I got with our '02, the heaters come on at 44F but don't go off again until 64F. There are three sizes of pads, all 6.5" wide. The 18" long one draws 5.5 Amps, the 24" one draws 6.3A and the 36" one draws 9.0A, all at 12 volts DC.
Frank and Eileen
No longer RVers or FR owners
Old 02-04-2011, 02:18 PM   #7
cfsoistman's Avatar
You're right about the temperatures on & off. I knew it was close to 40 but wasn't sure. Memory isn't what it used to be!
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 02-07-2011, 09:18 AM   #8
whitebb's Avatar
I was just wandering is there a way to regulate the on and off time of the heating pads. Say turn on at 28 degrees off at say 35 degrees. My thinking if its 32 out side then its 37 inside the tanks. Also I am wondering about the extra insulation in coach. Any information about this would be healthful. I mean a question should be answered by the designers or technical people and not sales staff.
whitebb is offline   Reply With Quote
Old 02-07-2011, 09:33 AM   #9
tncruiser's Avatar
when the artic pac is on does the switch have an indicator light in it
my switch has a lens on it but doesnt light
brianj
liven life in east TN and wherever my
2011georgetown280ve, and
2016 fordexplorer and hemi RAM
take us
tncruiser is offline   Reply With Quote
Old 02-07-2011, 10:16 AM   #10
Anacortesians
I think heating the tanks to 64F is a bit over the top, particularly for the black tank. The heating pads have the thermostat built in, I believe.
Frank and Eileen
