Old 10-25-2014, 05:57 AM   #1
tilap's Avatar
Artic pack
I could not find any paper work on my 2015 georgetown 377xl. Getting cold up here and need to know more. What does the arctic pack protects? I know it warm up the fresh water tank but what about black, grey, pipings etc?
tilap is offline   Reply With Quote
Old 10-25-2014, 07:06 AM   #2
The arctic pac should be on all of the lo point and elbows. When looking at mine nothing from the holding tanks back, since all the drains are supposed to be somewhat direct. I did not see anything on my unit for the black I did see some protection for the shower drain. Hope this helps.
Bill M
2012 Georgetown XL 360
2011 Chevy Equinox - 2006 Chevy Avalanche
Bill m is offline   Reply With Quote
Old 10-25-2014, 07:35 AM   #3
Sbryant's Avatar
There are heater pads on the fresh, black, & gray tanks. I have a GT 360 and can see them and their wires.
Sbryant is offline   Reply With Quote
Old 10-25-2014, 08:06 AM   #4
DarrenK's Avatar
I can see a heater pad on the elbow right next to the black and gray water dump valves...
DarrenK is offline   Reply With Quote
Old 10-25-2014, 08:43 AM   #5
Yes there are, I should have taken the quick walk outside and around.
Bill M
Old 10-25-2014, 11:46 AM   #6
ramair's Avatar
The Artic Pack is automatic just turn on the switch and they will turn on at approx. 35 degrees and will keep everything from freezing. It will not hurt if a tank is empty, we use it and our fresh water tank is empty on city water now.
Andrew & Donna Reyes
2012 Georgetown 378XL
2015 Ford Taurus
Our Baby Dachshund
Cammie
ramair is offline   Reply With Quote
Old 10-25-2014, 11:55 AM   #7
tilap's Avatar
Thanks i think ill sleep better at night now. Cant wait to travel to the souther states in the US
Old 10-25-2014, 12:14 PM   #8
abjb's Avatar
The artic pack likes batteries, it will drain them QUICK if you're not plugged in.
2012 Georgetown 360
SHE wanted "a new motorhome"
abjb is offline   Reply With Quote
Old 11-25-2015, 12:51 AM   #9
sirozz's Avatar
Hi,
Please confirm they are automatic when the switch is turned on? At what temps should one turn in the switch?
2016 Georgetown 350XL
sirozz is offline   Reply With Quote
Old 11-25-2015, 03:47 AM   #10
Witch Doctor's Avatar
Originally Posted by sirozz View Post
Hi,
They are on there own thermostat. Mine come on I think at 40 degrees read at the tank and go off at 60 degrees. I only turn mine on if I know it will be close to freezing... I do not own a Georgetown, but they are all the same.
Coachmen M/H
Concord
2018 / 300 DSC
Old 11-25-2015, 08:55 AM   #11
abjb's Avatar
Hi,
In N TX we usually turn ours on the second week of Nov., turn it off when in Galveston.
2012 Georgetown 360
Old 11-27-2015, 06:42 AM   #12
Should the artic pack switch light up when it is on as does the water pump switch?
surcy is offline   Reply With Quote
Old 11-27-2015, 07:21 AM   #13
Only if it is lighted switch, some are not.
Coachmen M/H
Concord
2018 / 300 DSC
