Forest River Forums
Sunline User Photos
Old 11-20-2011, 07:55 PM   #1
Wichitalineman's Avatar
Artic Pack Problem
I recently purchased a 2005 Georgetown 350ts. I was using the artic pack when all of a sudden it stoped working. I have checked the fuse and it seems to be ok. What do I need to do next?
Charlie and Joan Monckton
3309 S. All Hallows Ave.
Wichita, Kansas
Wichitalineman is offline   Reply With Quote
Old 11-20-2011, 08:21 PM   #2
Dave_Monica's Avatar
Just so we're clear, are you referring to the tank heaters when you say 'artic pack'?
Dave
2008 F250 CC SB 6.8L V10
2010 Rockwood 8280WS
Nights camped in 2010 - 58, 2011 - 43
Old 11-20-2011, 10:31 PM   #3
Pack all of your things and drive as fast as you can to either Arizona or southern Florida. Sorry,I couldnt resist. I wish I could help you out but I havent used the feature yet. The good news is this forum is packed plum full of experienced and friendly folks.
2011 Georgetown 341 DS
Phantom341 is offline   Reply With Quote
Old 11-20-2011, 10:44 PM   #4
Moderator
What are you referring to, and what makes you think it isn't working? Where are you, what is the temp, what are your symptoms? As a tech, you wouldn't believe the people that are now wanting us to find an air conditioner leak, temp outside 45 Fahrenheit. We can't even get a compressor to come on, much less find a leak. Oh yea, and while you have have it, winterize it. Kind of trying to check a furnace in July, ain't happening.
Windrider,
Too many toys, not enough time.
2001 F150 SuperCrew
2002 Jeep Wrangler
1978 Cessna 152
2000 Honda 750 Nighthawk
2008 Work and Play 18LT
windrider is offline   Reply With Quote
Old 11-21-2011, 09:57 AM   #5
Anacortesians
The heaters should come on at 40F and go off at 65F. Those temps are as sensed by a thermostat embedded in the pads. If the tank contents are warmer than 40 degrees, the elements don't switch on.
I wonder about the damage they could cause if the tanks were empty. Since I don't like the idea of heating up the black tanks to 65 degrees, I don't use the system. We bought the rig used and the "Arctic Pack" was part of the configuration.
Frank and Eileen
1 Rescued Male Labrador - Bailey, 9 in July
02 Georgetown 325, F53 V10
Old 11-21-2011, 04:16 PM   #6
Man I live in a cold climate and I wouldn't even think of turning those puppies on until around the 25F temp range..
polkatronron is offline   Reply With Quote
Old 11-21-2011, 10:34 PM   #7
I have read that the reason they say don't use the Arctic Pack if the tanks are empty is that they will push tank gas into the unit. I am not sure they will do damage to the unit itself. If the heating elements get hot they will simply shut off.
At least that is what i read into the instructions.
Rongrice is offline   Reply With Quote
Old 11-22-2011, 05:58 AM   #8
cfsoistman's Avatar
Not sure how a heating pad would push tank gas into the unit when the tanks are already vented to outside.
If that was the case when it hits 90 degrees outside for a few days or weeks the same situation would exist. Can't figure how someone would think this would happen???
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 11-24-2011, 07:57 PM   #9
A line slideouts
Ok just told someone else the same thing on a diff problem the switch can go bad so try and replace this first if all fuses are good. Anything more extensive then that take it to a service department.
Chuck692020 is offline   Reply With Quote
Old 11-29-2011, 07:59 PM   #10
The indicator light has gone out nad it is headed to 24 degrees tonight. I have been checking breakers and fuses. So far no luck. emp is already lpw enough it should be on.
Wichita, Kansas
Close [X]
