Attention: Re-wording problem with UFO rear suspension
I have a 2007 Georgetown 359XL 35' UFO gasoline pusher with a Workhorse chasis. 26,000 GVWR. The rear weighs 14,500lbs while the front weighs 8,500lbs. The front number includes 1,100lbs welded over axel. Wheel base is 228" and has Koni FSD shocks all around.
The coach porpoises while going over bridges or changes in road elevation. It handles great but is in need of a fix for the ride. The rear suspension seems to be rigid and has no travel in the coil springs or shocks. Thanks for your replies and patience.
